Engine Nitrous on stock fox body plugs and retard timing questions
Foxstang31
87
21
18
Recently bought a NX wet system for my 1990 mustang. Running a 140 fuel pump stock 19 injectors. I read that your supposed to pull timing 2* for every 50 shot of nitrous. Plan on running 150 shot so I would be pulling 6* right? Also what plugs and gap would you guys recommend for my setup?
If that head is typical 14mm .750 reach,gasket seat.
I would use a non-projected plug,like the NGK R5671A-8.
NGK plugs are very popular with nitrous guys because of the soft ground straps.
It will act like a fuse,if things go all bad.
Reactions: Foxstang31
