Nitrous + Preditor
i think you can if you get a custom dyno tune, (other wise NO) not 100% sure, my predator will be here on monday :nice: and within the next few months i will be doing a 75 shot of NOS also :D . but i wouldnt try it with out a dyno tune from a GOOD shop. you could blow the motor if you dont have the right a/f ratio..... :notnice:
Just use your stock tune and pull back timing and fuel.
Don't use the Predator "power" tune with nitrous, the added fuel/timing WILL blow your motor.
For a 100 shot pull about 2* of timing, I'm not sure what the equates to in the Predator % method.
Good luck and check your a/f ASAP.
i have a predator and the nos noszle kit.hooked up an lm-1 and discovered i was running rich with predator tune. i leaned it 2% and added 1.5% timing 4-7000 rpm.a/f now is 12.1 when nos initially hits then levels off to about 10.6-10.8!!!
