Nitrous Question
  • Thread starter Thread starter 87_5.0
  • Start date Start date May 7, 2005
87_5.0
73
  • May 7, 2005
I have a Nitrous Express kit, and i was wondering how big of a shot you guys thing i could spray with out hurting anything...my engine isnt stock, all the stuff i have done to it is in my signature. thanks,
Brent
sgarlic
3,085
May 8, 2005
  • May 8, 2005
I've never run it myself, but I know of quite a few people running 150 shots. Assuming your engine is in good condition to begin with, just get a good tune and take the proper safety precautions (window switch, etc) and you'll be ok.
Did I mention a tune?
G
grrrrrrr
289
norfolk, VA
May 8, 2005
  • May 8, 2005
300 shot should be okay... no, no no.. I need to lay off the sauce...
I'd say 125 with a few degree's less timing to be safe...
ninety15.0
1,336
  • May 8, 2005
What are your plans....are u throwing the nitrous on there just for fast ET's at the track or is this for a little kick in the ass for your street car. For a street car i'd run a 100 shot and be done with it....that way your not pushing any limits. Most of your motor is pretty stock though...you still retain the stock rotating assembly and stockish heads. Are you planning on just getting a chip or running a tweecer setup?
Rick 91GT
Mustang Master
95
99
PA
May 8, 2005
  • May 8, 2005
Start off with the lower setting and learn how to read the plugs and tune it. I ran 175 for years on a stock bottom end with no issues at all, tune up like anything is critical.
Do some small pulls turn the car off and read the plugs....only true way to know what is going on, if you let it idle it will change the reading on the plug. The bleuing on the ground strap will show you how your timing is doing, the porcelin will tell you how it is running rich/lean. I have a Moroso spark plug magnifier and it is worth every penny.
The NX stuff is very nice, be sure to blow out all the lines before installing, also never use TEFLON tape, always use liquid. I have 2 brand new 2-1/16" Autometer Phantom pressure gauges if your interested, white faced.
T
TheRipper
30
  • May 8, 2005
I agree with the above.But alos make sure you are getting the proper fuel you will be needing and also keep some high octane in the tank.I have pushed stock motor's to a 225 shot with no problem's before but that one back fire will be what kil's it at the size of a shot.I run a seperate fuel pump for the nitrous because of one back fire I had at a 175 shot.Luckly it did not hurt it just left a little burn mark on the piston and blew out the head gasket and warped the intake.150 shot is really safe to mess with.
Need some camshaft guru advice on power loss from supercharger to nitrous
  • TTSaleen
  • Dec 1, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 29, 2025
revhead347
R
Fox Hydroboost conversion/proportional valve
  • RubyRedNotch
  • Jul 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 20, 2026
RubyRedNotch
R
H
Forced Induction On3 Turbo Kit- Parts list NEEDED - 302 Stock Motor
  • Hirothecool1
  • Feb 27, 2026
2K
Fox 5.0 Mustang Tech Mar 7, 2026
slow84lx
Stuck
  • bshipley
  • Aug 27, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 28, 2026
squeak93
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
