nitrous question?
pistonhead351
flim hunter
May 1, 2005
75
i was looking at getting the trickflow plate system for my car and i was just wondering if i should go with that one or get a different brand/style. also what needs to be done for tuning, say if i go with a 75-100 shot? just retard the timing a little? thanks.
i think pretty much everyones nitrous system are the same. yah run cooler plugs and step the timing back 2 degrees for every 50 hp shot of juice. i think an adjustable fuel pressure set up is nice aswell. specially if you are going to be teeing into your current fuel system.
I have the trickflow kit.
Nice kit, it comes with jets for 50-100-150-200 hp increases. If you change out the nitrous and fuel solenoids it can go up to 300. Basically all of the solenoids and bottle and stuff are from Nitrous Express. Pretty easy to install. my only problem was I had to fab a mounting plate for my solenoids cause I couldn't find anywhere to mount them with the stock brackets that looked like I wanted it to. Other than that it was pretty top notch.
Like everyone has said drop your timing back 2 degrees for each 50hp. If you normally run 14* then you would drop it back to 10* for a 100 shot. Use a one step colder plug and gap them around .035-.038. Run at least 91 octane and you will be good. I would look at also upgrading the fuel pump to the 255 lph pump. Since it is a wet kit you won't have to worry about upgrading the injectors since you are getting your fuel via the fuel solenoid and jet.
You can look in my sig and see my mods and see what just a 50 shot did. I just bumped it up to a 100 and am gonna be out at the track on Wednesday and see if I can put it in the 12s.
hey PISTONHEAD351......I am running a nitrous express wet kit.....nitrous express rates their jets (# of hp being sprayed) at the wheels. It is an awesome kit I personaly would go different, i am currently running a 75 shot on my 347 and its so ****ing torquey its not even funny, i retarded the timing 4* just to be safe...i run a plug 2 steps colder...and always run 91 octane....make sure you get a wide open throttle or some other safety switch just in case, i plan on sprayin 100 and 125 soon but i will be staying with the 75 until i get a custom dyno tune for thebigger shots.....as far as trickflow and other kits.....i cant say postive or negative things...i just know nx says the hp shot you put is at LEAST what you will get at the wheels.....the only kit i will dog on is ZEX dry kit had it before and unreliable to me......make sure you get a wet kit either way....good luck keep us posted
Not sure o your question about judging for injectors but i think therule of thumb is 300 H.P mark is cut off for #19's then it time for #24's. Another question is what color is NOS jets and what color are the fuel ones for a wet kit? I have a wet kit that i took off my 95 before i sold it but now i cant find the jets i had in there and going by the chart i dont even have enough to run a combo, my jets are goldish and silverish so whats what? I was going to hook it up this week in hopes of going into the 11's but i cant remember what jets were what? peace
john:p
