  • SN95 4.6L Mustang Tech
Nitrous questions
  • Thread starter Thread starter pieromj3
  • Start date Start date Jul 31, 2005
P
pieromj3
35
Central PA
Jul 31, 2005
  • Jul 31, 2005
Can someone explain the difference between a dry and wet kit?
How big of a shot can a stock engine take?
What parts would be needed to take a 150 shot?
thanks
CanadaStang
2,093
Mb
Jul 31, 2005
  • Jul 31, 2005
A dry kit injects straight nitrous into the engine, where as a wet kit mixes the nitrous with fuel as it injected.
forpit2000gt
2,490
Columbia, SC
Jul 31, 2005
  • Jul 31, 2005
a dry kit relies on the computer to add the additional fuel and a wet kit adds the correct amount of fuel for the shot you are using with the nitrous. You should buy a kit with a rpm window switch and you will need a colder plug. NX or NOS kits will recommend exactly what you need. There is also a fuel pressure saftey switch that can be used. Most kits up to a 150 shot are designed to use the other stock engine parts. A Tune with the nitrous is a good idea.
streetstang03
unModerator
Dec 27, 2003
the dark side of the moon/home of the 1999, 2003,
Jul 31, 2005
  • Jul 31, 2005
dyno tune.
P
pieromj3
35
Central PA
Jul 31, 2005
  • Jul 31, 2005
anyone run 150 shot on a stock 96-98 gt?
03gtmustang
923
Northern Va
Jul 31, 2005
  • Jul 31, 2005
Its not so much as how big the shot is, but how much power you make with each shot. 400rwhp should be your stopping point. I HIGHLY recommend an NX kit with Genx2, MSD window switch, and a dyno tune.
9
97gtblue
283
pensacola,florida
Aug 1, 2005
  • Aug 1, 2005
i have my nx, but im only running a 100 now but about to bump it up too 150 after i get my truck
BooWFO
991
Louisville, KY
Aug 1, 2005
  • Aug 1, 2005
grasshopper start small and work up. Also keep in mind if your bottle pressure isn't high enough you won't feel it as much. Personally after looking at the lower intake I won't go over 125 shot and I'm happy (ok for now) with the 100 shot. I just think it's too much fuel flowing through the intake and too big a chance for a puddle and boom. Also I doubt you can go over a 100 dry shot. If your wanting to hit it with a 150 a focus pump would be a good idea and so would a tune.
forpit2000gt
2,490
Columbia, SC
Aug 2, 2005
  • Aug 2, 2005
wet kit , window switch so that it will not spray under at least 3000 rpm=no puddling. As with any nitrous application, there is always more risk of something failing. A wet kit still uses the same fuel pump, it just adds the fuel through the intake. A dry kit , the computer adds the additional fuel through the injuctors. Properly tuned you can get by with a 150 on the stock fuel pump. get a fuel pressure saftey switch. smallet shot is deff. safer bet.
P
pieromj3
35
Central PA
Aug 6, 2005
#10
  • Aug 6, 2005
  • #10
which is better for a 98 gt? Wet kit or a dry kit. i am going to purchase a NX kit here soon and would like to know what to get.
forpit2000gt
2,490
Columbia, SC
Aug 6, 2005
#11
  • Aug 6, 2005
  • #11
Check with a NOS ditributor or call Holley. The NOS Dry kit pn/ 05171nos( I believe this is the right kit) is a nice easy to install and works very well. I really like the NX wet on 99+ but the NOS on pre 99. It can be set up for 75 to 150 and uses stock equipment. Make sure you are running copper plugs and I like a step colder. Do not run with platinums. Are you using any kind of timing advance or programmer? if so , you will want to put timing back to stock. Follow manufacturers reccomendations for tune and install.
Need some camshaft guru advice on power loss from supercharger to nitrous
  • TTSaleen
  • Dec 1, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 29, 2025
revhead347
A
A/F ratio gauge install questions.
  • AngryH58
  • Sep 24, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 22, 2026
R
Suspension Lower control arms needed
  • racer_dave
  • Feb 9, 2026
1974 - 1978 Mustang II Talk & Tech Feb 20, 2026
G
79 steering rack problems
  • garyrc
  • Mar 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 8, 2026
AeroCoupe
D
N/A build on fresh stock 302
  • djcarrot
  • Oct 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 19, 2026
AeroCoupe
