Hey guys, I'm installing my nx 100 shot currently. I have a question, I have an sct xcal2 with a 93 octane tune, so I'm assuming the timing is maxed out, how much should I bump the timing down by?>?
Yes you are correct sir.kyles03sonicgt said:Ok, so for now I'll put back the stock tune on the car and bump it down by 2 degrees with my 100 shot right?? I've got a window switch, a fuel pressure safety switch, and colder plugs, i should be all set right?? And is the saying you should retard your timing 1 degree for every 50 shot?
Yes the stock timing is ten degrees.kyles03sonicgt said:So maybe you think I could start on bumping the timing down 3 degrees, check my plugs, then if we're good try it at only 2 degrees?? Isn't the stock timing 10?? and how do you check the plugs if they're lean?? Arent they a specific color??
Congrats I hope all go's we'll with your install.kyles03sonicgt said:Easy enough, I'm really stoked to get my kit installed completely. I already have all the solenoids mounted and the jet is drilling into the intake, I'm just waiting on my darn bottle brackets. How hard is it to install a bottle heater, window switch, and purge kit??
I ran the nitrous line through the inside of the car under thekyles03sonicgt said:Where did you connect the nitrous line under the car to run into under the hood?
