I have all stock fuel system running a 125 zex wet kit. You do need to have two seperate tunes for the nitrous and street. You can get away with backing off the timing and driving normally like that, but it will not run as well on the motor with timing pulled out of it. So you can run one tune if you want. If you go with a dry kit i would upgrade injectors because the dry relies completely on your stock injectors to deliever extra fuel.
