  • SN95 4.6L Mustang Tech
Nitrous ? ? ?
  • Thread starter Thread starter jt98boost
  • Start date Start date Aug 25, 2005
J
jt98boost
167
United States <><>
Aug 25, 2005
  • Aug 25, 2005
Would a 35-50 dry shot of nitrous be ok for a vortech supercharged cobra with a air fuel ratio of high 11?? Just wanting to get that little extra boost, and get my torque up a little
twogts4us
4,188
12
79
Dunedin, FL
Aug 25, 2005
  • Aug 25, 2005
You'd likely gain more of a cooling effect from the nitrous than actual power from it with this combo...but cooling is power too - just want to clarify how it would make the power. And because of the cooling, it allows higher AFR and/or timing. My 2 cents - this should be safe.
J
jt98boost
167
United States <><>
Aug 25, 2005
  • Aug 25, 2005
Yeah I have heard of people spraying a small shot for cooling, I do have an aftercooler to help cool the air, but I believe the nitrous still would help me greatly
Think I will start with a 35shot then maybe a 50shot, dry should be fine right?
J
jt98boost
167
United States <><>
Aug 25, 2005
  • Aug 25, 2005
Wonder how long a 9OZ bottle for nitrous would last spraying a 35 shot??
J
jt98boost
167
United States <><>
Aug 26, 2005
  • Aug 26, 2005
ALso where would I spray it at, before the mass air is what I have heard??? Is that right, that means it will go through the mass air, supercharger, aftercooler, and then enter the engine. Anyone got any ideas??
M
MEAN03GT
42
Colleyville, Texas
Aug 26, 2005
  • Aug 26, 2005
About 30 seconds.
J
jt98boost
167
United States <><>
Aug 30, 2005
  • Aug 30, 2005
Thanks that sounds good to me, anyone ever used the shad shot nitrous system, just wondering how good this kit is. Think I would be ok spraying a 35shot without getting a retune??
BooWFO
991
Louisville, KY
Aug 30, 2005
  • Aug 30, 2005
A local cobra owner is using a NX kit with a 35 wet shot he saw an increase of 56rwhp with it. Build motor, vortech, etc..
Personally I won't do a dry shot on your combo but that's just me. Can you monitor your AF ratio? if so then you may not need a tune just watch it. Of course the safest action would be to go put it on a dyno with a wideband and at least check everything. Have you considered going with the Watermethanol injection?
Need some camshaft guru advice on power loss from supercharger to nitrous
  • TTSaleen
  • Dec 1, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 29, 2025
revhead347
C
Boosted Boss 302 HP/TQ
  • coltoncaskey12
  • May 24, 2026
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech May 24, 2026
coltoncaskey12
C
3.08 gears with a manual trans
  • limp
  • Aug 27, 2026
  • 2 3
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 14, 2026
Qtrhrse23
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
D
Fuel pump upgrade
  • dkrupp79
  • Jul 7, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 10, 2025
Scrapla347
