Nitrous?
  • Thread starter Thread starter TE56
  • Start date Start date Aug 5, 2010
T
TE56
15
  • Aug 5, 2010
on a stock 5.0 engine? stupid or smart
tannerc91gt
This last 25% is foreign territory at this point
2,967
234
Indiana
Aug 5, 2010
  • Aug 5, 2010
Depends on what year motor and what size shot.
Ive run a 150 wet shot through a stock bottom end countless times without issue, but there's also going to be guys breaking parts running the same size shot, there are a lot of variables
T
TE56
15
  • Aug 5, 2010
yeah, i have a 91, but i woudnt do it unless i get the other parts and if it coudnt handle it
tannerc91gt
2,967
234
Indiana
Aug 5, 2010
  • Aug 5, 2010
91s have forged internals. You should have no problem spraying a decent shot to it as long as you do everything else (colder plugs, retard timing etc)
T
TE56
15
  • Aug 5, 2010
ok thanks man
2000xp8
SN Certified Technician
Aug 8, 2003
8,071
1,655
194
NJ
Aug 6, 2010
  • Aug 6, 2010
While there are no issues using it, i personally don't think it falls under the smart for everyone catergory.
And yes i have used it.
Kit's can be expensive, extras for the kits cost good money too, then you have bottle refills, which in some areas can cost up to $50 a pop.
Nitrous money adds up quickly, and while it does give you a kick in the pants now and then, a H/C/I setup is far superior for fun.
So if you want to go faster and you already have a h/c/i setup and cant' afford a supercharger, i understand it's use.
But if your engine is stock, spend the money on heads and bolt on parts instead, i guarantee on a daily basis the heads are more fun to drive.
Keep in mind guys are getting 50rwhp with explorer take off gt40p parts for around $600. That's only about 25rwhp less than a 100 shot of nitrous gets you. Except you get to enjoy the gt40 parts on a daily basis.
90lxcoupe
20+ Year Stangneter
Oct 7, 2003
3,596
350
134
Aug 6, 2010
  • Aug 6, 2010
Nitrous money adds up, and while it does give you a kick in the pants now and then, a H/C/I setup is far superior for fun.
very true, i think its funny when people call nitrous "cheap" if you do it right its definitly not cheap. By the time you get the kit, then a window switch, then a bottle heater, then gauges, then a blowdown tube, then a purge kit, and you still havent filled your first bottle yet. But juice is ALOT of fun... till the bottle is empty
Slatco
29
  • Aug 6, 2010
Hmmm. Kinda disagree. I spent $550 on a Zex nitrous dry kit and went from a 14.4 at 94mph to a 13.1 at 106 mph. (125HP shot) For me it was worth it cuz I was stomping new, albeit traction limited corvettes and camaros and I am still running stock HCI. I don't think I could have got there with just a explorer intake.
For me I am saving up for a complete longblock stroker engine and the spray was a way for me to have some short term fun. I never run it on the street so I can get quite a few passes on it.
Each to their own, although I have a hard time wiping the smile off my face every time to spray comes on.
2000xp8
Aug 8, 2003
8,071
1,655
194
NJ
Aug 7, 2010
  • Aug 7, 2010
A. There was something wrong with your original run.
14.4@94 has a very low mph.
B. Stock 430hp corvettes run the quarter around 12.5@115+ (even 405hp vettes run easy 12's).
C. The explorer part that makes the difference is the Heads. And yes with the intake they will easily run 13.1@106mph.
D. Picture that smile all the time, and costing you $0 a clip.
And entire explorer engine only costs $550.
Slatco
29
#10
  • Aug 12, 2010
  • #10
1. Please explain. Sounds like I have an opportunity for improvement on my N/A time.
2.No question the vette should be running faster on street tires. The guy probably cant drive.
Need some camshaft guru advice on power loss from supercharger to nitrous
  • TTSaleen
  • Dec 1, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 29, 2025
revhead347
Engine Brackets for Gt40 heads with ac and ps?
  • Xavierg208
  • Nov 14, 2025
Fox 5.0 Mustang Tech Nov 16, 2025
limp
J
Engine Tuning...?
  • justadude07
  • May 30, 2026
Fox 5.0 Mustang Tech Aug 21, 2026
Qtrhrse23
M
Idle problem
  • miser143
  • Oct 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 11, 2026
CAMTWO1070
I
Removing NX NOS kit?
  • ironhorsewayne
  • Jun 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 8, 2026
squeak93
