  • 1994 - 1995 Specific Tech
No A/C...why?
  • Thread starter Thread starter TrueBlue95GT
  • Start date Start date Oct 20, 2004
1 of 2 Next Last
TrueBlue95GT
966
Connecticut
Oct 20, 2004
  • Oct 20, 2004
I park my car at home while I'm at college. One weekend I came home and I have no A/C anymore. I get heat, but the Normal A/C and Max A/C don't push out cold air. Also, I noticed that the defroster doesn't take the humidity out of the air as well as they used to. What could be my problem?
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Summerville,SC missing South Fl. weather :(
Oct 20, 2004
  • Oct 20, 2004
Does the compressor turn on at all? If no then pop the hood open and on the pass. side the accumilator*sp* has a pressure switch sitting on top of it( a little black container). Unplug the switch and bypass it using a paper clip or something and see if it turns on.
C
Chronos[AsG]
86
NC
Oct 21, 2004
  • Oct 21, 2004
Yeah well dont bypass it too much. Mine did the same thing, just one day I had no more cold air. Turns out I had a leak in one of the a/c lines and eventually enough refrigirant leaked out to where the compressor wouldnt come on anymore because of the low pressure switch. Have a shop check your refrigirant level as you could easily have a hard-to-see leak. Running it too much without enough refrigirant will burn up the compressor because there is also oil in the a/c line to keep the compressor lubricated.
ARed1995GT
401
Boca Raton, FL
Oct 21, 2004
  • Oct 21, 2004
does it blow out of the defrosting vents only?
J
juannaplay
  • Oct 21, 2004
Easy Fix?
Check and see if your clock on the dash in still on. If it is off. You need to replace the fuse under the driver side. The clock and the A/C clutch are on the same fuse. You might have to go to a 30 amp fuse. The factory put a 15amp in.
TrueBlue95GT
966
Connecticut
Oct 21, 2004
  • Oct 21, 2004
The clock in the dash works, the air comes out of every duct when I want it to, so the vacuum line is not leaking. I gotta see if the compressor turns on. I do have coolant running through those two heater lines over the lower intake.
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Oct 21, 2004
  • Oct 21, 2004
Please DO NOT do that those wires can only handle so much resistance before the wires begin to melt and expose them selves. By add a much higher fuse it may not pop the fuse in time to prevent the wires from melting and exposes/touching one another.
smokediver27
203
Florida
Oct 21, 2004
  • Oct 21, 2004
Check your freon level first, like they said, if it is too low, or too high, the pressure switch will keep your AC from coming on. If freon is ok, and compressor seems to be engaging, then bypass the switch quickly like they said. Just replaced my switch two weeks ago, 16 dollar part at autozone. Air works perfectly now.
TrueBlue95GT
966
Connecticut
Oct 22, 2004
  • Oct 22, 2004
I'm pretty incompetant when it comes to anything other than engine parts, so how do I check my freon level?
Venom351R
4,548
41
98
MAINE
Oct 22, 2004
#10
  • Oct 22, 2004
  • #10
Whats that mean when it does, I cant get anything to come out of my vents that face me but they come out for the defrost for the window
H
helix007
71
#11
  • Oct 22, 2004
  • #11
dude take it to a shop
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Oct 22, 2004
#12
  • Oct 22, 2004
  • #12
You have a vac line either disconected or broken. Check along the firewall I had a vac line break and the air would only come out of the defrost vents.
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Oct 22, 2004
#13
  • Oct 22, 2004
  • #13
Why? If we can help him fix it for a fraction of the cost and he learns in the process that's what this place is for.
Venom351R
4,548
41
98
MAINE
Oct 22, 2004
#14
  • Oct 22, 2004
  • #14
I was thinking along those lines since it dident make sense that I was just out of freon since my vents facing me were not working. I'll figure it out next spring, Im done messing w/ the car this yr.
go-stang5.0
2,244
Glenview,Il
Oct 22, 2004
#15
  • Oct 22, 2004
  • #15
If you know antone with a ac oressure gauge check the pressure in the system when its off...(should be around 120 psi) dont quote me on this. But if there is a good amount of pressure (around 100 or so) you have no leaks. And yes use a paper clip to jump the pressure switch on the accumulator. And dont worry when unscrewing it theres a check valve underneath so refrigerant wont leak out. Like said before dont jump for more than a second or two if the compressor comes on, keeping the comp. on like that can cause it to explode.
H
helix007
71
#16
  • Oct 22, 2004
  • #16
I really mean no offense to the original poster but reading his posts he sounds VERY inexperienced and VERY incompetent concerning Ford A/C and is going to spend a LOT more time and money than he would if he took it to someone. They don't necessarily have to fix it, just tell him what's wrong.
Then maybe he could attempt it.
The shorting of the low pressure switch is very basic electronics and it seems like even though you guys told him several times what to do and how to do it, he still didn't know what you guys were talking about.
My advice would be to buy a haynes manual, read up on the A/C section, figure out how it works, then come back and read this thread, ask a few more questions, and it will make a LOT more sense.
I was lucky because someone taught me how it works, in a hands on lesson of my old 87 5.0 some years ago.... I was able to recently fix the A/C on my 95, (after asking a few questions here about what kind of freon to use in a 95 and if anything has majorly changed between 87 and 95) by figuring out that the low pressure switch was bad....when I shorted it out, the compressor would kick on. HOWEVER, when I checked the pressure, it was reading the perfect nominal pressurization.
voila, new low pressure switch from autozone (18$) = cold A/C
good luck tho
TrueBlue95GT
966
Connecticut
Oct 22, 2004
#17
  • Oct 22, 2004
  • #17
It's not like I don't know anything about Mustangs, but I've never worked on the A/C system before. I've learned everything I know about cars through my mustang, and this is the first time anything has gone wrong with the A/C. I know what they're talking about, but I'm at college right now and I can't go 100 miles back home everytime a new post comes up to try and solve the problem. When I turn the A/C on, the clutch doesn't turn, but every once in a while it jerks slightly. I'm guessing I need a new pressure switch?
smokediver27
203
Florida
Oct 22, 2004
#18
  • Oct 22, 2004
  • #18
Only thing that confuses me trueblue is that when my switch was bad, the fan still blew air...just hot air. Seeing as how yours is not blowing at all,,,leads me to believe something else is the problem.
Actually,,playing mustang armchair QB, sounds like two separate problems. One is causing your fan motor not to blow. The other is causing your compressor not to kick in.. I'd guess the pressure switch is one part of the problem,,,unsure on the other.
hawaiian
321
South Miami Fl
Oct 22, 2004
#19
  • Oct 22, 2004
  • #19
Well if it just stopped working its probably not a leak they tend to slowly loose charge.
check the wire harness that goes to the compressor mine just fell out; twice. maybe thats all that happened to yours.
If you turn the AC on MAX does the idle start to go up and down?
you should here a clicking noise when the compressor clutch engages.
TrueBlue95GT
966
Connecticut
Oct 25, 2004
#20
  • Oct 25, 2004
  • #20
I'm not saying my blower motor is bad, it just doesnt blow cold air. Yes the idle goes up and down within a period of a second when the compressor clicks, but the compressor doesnt keep on turning. It clicks and stops.
1 of 2 Next Last
A/C Issues
  • Boats90GT
  • Jun 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 11, 2026
Mcmahst
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
A/C blowing defrost
  • 70/04mach1
  • Jul 20, 2025
1996 - 2004 SN95 Mustang -General/Talk- Jul 21, 2025
2000 GT-Front Brakes Not Releasing
  • stormsedge
  • Aug 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 7, 2026
Bronco2fan
M
Idle control problems
  • miser143
  • Aug 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 29, 2026
DadLife0724
