No backup lights no hazard flashers?
The hazard lights use a flasher mounted in the middle of the fuse panel.
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring http://www.veryuseful.com/mustang/tech/engine/
Backup lights:
Check the bulbs first to make sure they are good. Next check the driver's side of the transmission to make sure the backup light wiring is connected to the switch.
attachment.php
See http://forums.stangnet.com/showthread.php?t=646561 for pictures of the wiring connector & some more help.
If the wiring is good & is connected, the switch may be bad.
