No compression problems!!!!!!!!!!!!!!!!!!!!
  • Thread starter Thread starter snailpower302
  • Start date Start date Feb 16, 2009
snailpower302
11
  • Feb 16, 2009
I checked my compression on my 93 5.0 with gt-40p heads and e303 cam with i think 1.6 roller rockers but only two cylinders and anything! cylinder number 2 was at 105 cylinder number 3 was at 125 all the others where 0! I pulled the heads the valves look fine and the head gasket looked good to! What could be the problem maybe wrong push rods or cam installed wrong! i didn't do the work to the car now i am just trying to fix it! Any comments thanks
C
cheese_05_70
58
IL
Feb 16, 2009
  • Feb 16, 2009
Did you check and make sure your roller rockers werent adjusted too tight and holding open the valves. Sometimes you have to shim them.
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Feb 16, 2009
  • Feb 16, 2009
If you just installed them, your valvetrain is adjusted too tight, as noted above. I did the same thing with my TFS heads the first go around, when my lifters pumped up after I primed the oil pump and held the valves open.
snailpower302
11
  • Feb 16, 2009
ok now tell me how to adjust the rockers they are crane cam 1.6 roller rockers
T
Oil burning on my recently buil 302
  • The blk67
  • May 15, 2026
Fox 5.0 Mustang Tech May 15, 2026
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
J
'04 3.8L V6 mineral deposits and oil on #3 cylinder. Does it need a rebuild or something simpler?
  • joeybuddy96
  • Mar 18, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 29, 2026
gkomo
9
Forced Induction Prepping for supercharger on non-stock build
  • 91fox427
  • Nov 25, 2025
Fox 5.0 Mustang Tech Jan 5, 2026
Qtrhrse23
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
