No electrical power
sigsauer226
Hey all,
I have a 88 Notch, Yesterday i replaced a few burnt out lights on my dash console. Now i have no power. Lights, hazards, ignition is all out. Any ideas what could have caused this. I've checked everything over and over the only thing i think it might be is on the back of the gauge console there is a ribbon cable... Im not too sure where its supposed to be anyone have ideas its on the left side of the console when looking at the back of it... Any help would be great. Thanks
Get out your voltmeter or DVM and start with the ignition switch. They are a known problem source.
Check the diagram to give you some keys as to what fuses source power from the ignition switch.
Check the fuses to see what fuse sources power for what accessory.
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring http://www.veryuseful.com/mustang/tech/engine/ Everyone should bookmark this site.
Ignition switch wiring
Vacuum diagram 89-93 Mustangs
HVAC vacuum diagram
TFI module differences & pinout
Fuse box layout
Still have no power... I checked all the wiring a third time... Nothign shorting out as far as i can see. Checked the ignition switch... Got readings all over the place... I dont know... im confused Anyone to help... Im totally lost and need some help step by step would be great.
Replace the ignition switch. While you are at it, carefully inspect the ignition switch wiring connector to make sure that none of the wires are loose and falling out of the plastic connector shell.
Be very concise in your observations. For instance, when you said, "Checked the ignition switch... Got readings all over the place... " I didnt know what that meant.
Explicitly stating whether constantly powered items like headlights, dome lights, etc work helps. It seems like you noted that such items are not working. I would be looking for things like a connector behind the cluster that was left disconnected or fusible links or fuses that got burned during a short.
