  • SN95 4.6L Mustang Tech
No fuel, Need help ASAP
  • Thread starter Thread starter mat82284
  • Start date Start date Apr 18, 2009
First Prev 2 of 2
G
GT Tommy
190
#21
  • Apr 20, 2009
  • #21
No fuel at fuel rail?
Very good! I'm glad you found your problem. I'm not familiar with how the double fuel pump hoses run, but I did think you had a fuel pump related problem. Hope it doesn't happen again. Good luck and good find, Tommy.
M
mat82284
889
#22
  • Apr 20, 2009
  • #22
Thanks, Basically its two pumps that have seperate hoses coming from each, then each hose connects to a 2-1 (T) and that takes those 2 hoses and brings it down to 1 and then you connect that one hose to the top of the fuel hat for the fuel to be sent.
Basically this is what happened. One fuel hose on one fuel pump broke open and created a pressure leak, so it was enough pressure to send the fuel past the fuel filter, but not to the rails.
I have a feeling that the leak started before i filled my tank, but because the whole tank was pressurized at that time it didnt affect it in any way, but as soon as i filled up and popped that cap of it depressurized the car and that is why i got stuck 4-5 miles away. At least that's just my theory. Could be wrong.
G
GT Tommy
190
#23
  • Apr 20, 2009
  • #23
Double Fuel Pump Operation?
My thought would be, is the fuel line hoses designed to take the pressure from the two fuel pumps. Almost appears that at a given moment, one of the hoses will experience some restriction, which would put more pressure in that line. Something to think about. I guess you will know if you decide to put the pedal to the metal again! Good luck, Tommy.
84stng
roseville
Jul 17, 2010
#24
  • Jul 17, 2010
  • #24
help
yeah it sounds like you have a clogged line. i have a similar problem. my girl has an 84 mustang 3.8 v6 i really need help on it. it runs fine if u start it with starting fluid but wont send gas in the cranking position. the fuel pump is new and the ignition switch is as well. im stuck guys hel me out?
First Prev 2 of 2
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
C
03 Cobra Low Fuel Pressure
  • CTsnake_03
  • Mar 17, 2026
1996 - 2004 SN95 Mustang -General/Talk- Mar 24, 2026
CTsnake_03
C
M
Bad starter?
  • mason5.0
  • Oct 6, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2026
General karthief
I
1994 Cobra - Fuel Pressure Drops Revving at Idle
  • IconicSilverGT500
  • Apr 11, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Apr 24, 2026
Mcmahst
Fuel rail help
  • stang9150
  • Mar 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 5, 2026
stang9150
