No Horn, No Foglights, No Brights
seabas2020
20
I have a 2006 mustang gt. I don't have a horn, foglights, or brights. I have checked the fuses and swapped relays and that didn't change anything. I have tried both pushing the horn, and using the panic button, and it doesn't respond to either. Any ideas?
I suspect water in the SJB. Look around in/behind it. Check passenger floorboard area too. While you're at it, check the grommets under the hood (search water leak here). I'd bet it is stopped up, and your cabin air filter is probably nasty to boot.
