  • SN95 4.6L Mustang Tech
No ignition
  • Thread starter Thread starter 93 331 GT
  • Start date Start date Jun 8, 2009
9
93 331 GT
60
Jackson, NJ
Jun 8, 2009
  • Jun 8, 2009
My 99 mustang died today. I was taking the car to the inspection station when the check engine light came on then the car just shut off. it would not restart. No ignition motor is turning fine and you can smell the fuel. Checked the fuel line just to make sure it had pressure-there is plenty. Car will not start at all even after cooling off any thoughts
trinity_gt
3,125
81
99
Canada
Jun 8, 2009
  • Jun 8, 2009
First instinct would be the crankshaft position sensor. It's up on the front passenger side of the engine under the AC compressor. Make sure the connector is properly seated. Any work done to the car lately?
9
93 331 GT
60
Jackson, NJ
Jun 9, 2009
  • Jun 9, 2009
Yep. Motor was put in on Friday. Car ran all weekend. I did forget to mention that it threw codes 1132, 1152, 0172, and 1500. I looked these up and the first two indicate a rich condition in the left and right bank. It seems that the entire ignition system was week to begin with. The car was sitting for almost a year while I was on deployment. I did swap out CCRMs just to make sure that wasn't an issue. Also all fuses are fine. it ran all weekend (at idle) for thirty minutes at a time. I will take a look at the sensor though.
9
93 331 GT
60
Jackson, NJ
Jun 9, 2009
  • Jun 9, 2009
Plug is seated. Maybe a Bad Sensor??
9
93 331 GT
60
Jackson, NJ
Jun 9, 2009
  • Jun 9, 2009
replaced cam and crank sensor. Took alternator and battery to autozone. Alternator checks good battery is good but is not being charged ( low voltage) I'm starting to think PCM. That's the only thing left in the loop. Like I said earlier the car was running this weekend. Any thoughts ? Anyone???
F
2004 Mustang GT – Fuel Pump Not Priming
  • Fayio
  • Apr 22, 2026
SN95 4.6L Mustang Tech Apr 27, 2026
n0v8or
N
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
T
Help with a 95 5L crank no start
  • TheBubbaJoe
  • Nov 4, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Nov 5, 2025
AeroCoupe
M
2001 cobra ignition timing off
  • Mike3
  • Jul 13, 2026
  • SVT Tech Forum
SVT Tech Forum Aug 2, 2026
Mike3
M
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
