No jacking on the rear diff.
Just be careful. They used a pretty cheap cover from the factory. Just make sure the diff cover isn't being touched and you'll be fine.
+1. i have used the diff many times. the cover will bnend real easy if you are not careful. that could also cause a leak.
Thanks guys, that is really good to know. I have always been afraid to use the differential since the manual says not to. When my J&M relo brackets and LCAs come in this week I will have to give it a try.
Actually, you want to use the diff with those, because you need to torque the LCAs under load.
