No low end grunt
  • Thread starter Thread starter matthebr
  • Start date Start date Jan 30, 2007
M
matthebr
  • Jan 30, 2007
Hi guys, I have a 89 gt convt. with an aod, stock motor with a Novi 1000. The car makes around 5# of boost at wot and seems to move on pretty good once it gets going. My problem is it won't break the tires loose when I power brake it, I think it still has the stock gears(308s?) and it has alum. drive shaft, OR h-Pipe, and catback. What can I do to get this thing to move out of the hole? Thanks for your help.
poneypower89
Now everyone in the world will know I wanna bang t
Dec 6, 2004
Indianapolis, Indiana
Jan 30, 2007
  • Jan 30, 2007
up the gears to around 4:10's.
Beef up the tranny with a shift kit and high-stall.
You will have no problems get'n the tires spinning after that
5.0 Nostalgia
904
CT
Jan 30, 2007
  • Jan 30, 2007
I agree. Gears and a higher stall converter. Mine old GT convertible was the same way. Even with 3.73's, the car would barely spin the tires at the track.
M
matthebr
  • Jan 30, 2007
That's kinda what I was thinking also, but wanted to hear from someone that has had the same experience. Thanks guys
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Jan 30, 2007
  • Jan 30, 2007
The gears have to go. But make sure that you do a high stall. To many people over look this piece. Don't buy an off the shelf torque convertor. they are crappy. Get a custom built one for your car. The wieght of your car, etc, etc, etc.
1Fine89stang
87
  • Jan 31, 2007
Everyone says to go to a higher stall , but can you go too high? I'm building my car with a c-4 and it will have a vortec s-trim on an otherwise bolt-on only engine. Can someone please give me an idea of what rpm stall to use , i have been trying to figure it out for weeks . P.S the car is a weekend warrior and will see the track a couple times a month.
payupsucka
324
Keeping it grimy in Fall river MA.
Jan 31, 2007
  • Jan 31, 2007
that is probably the best advice your gonna get, pretty much off the shelf stuff is for mostly stock cars once you start pumping out power is moves into another realm of parts ie custom cams, converters so on
RYC CUKR
1,437
Orlando
Jan 31, 2007
  • Jan 31, 2007
That is why you go with a custom stall converter. You fill out an info sheet on the car, weight, gear, HP, TQ, cam specs, intended use, etc. and they build the converter around what YOU want so it is near perfect match to your car.
To the original poster. Gears even without the higher stall converter will wake the car up. But gears w/ a higher stall converter will make it a whole different animal. I would also HIGHLY recommend that you add a transmission cooler on since heat=fried AOD.
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
J
Lost low end torque
  • JJ's90fox
  • Jun 12, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 5, 2025
Methodical
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
New Member with a 1992
  • Clutchfork
  • Oct 18, 2025
  • The Welcome Wagon
The Welcome Wagon Oct 19, 2025
Clutchfork
Engine 1990 LX 5.0L EFI Mustang Fuel Management Problems - HELP!
  • 5.0LXStanger
  • May 25, 2025
  • 2 3
3K
Fox 5.0 Mustang Tech Jul 11, 2025
5.0LXStanger
