Well, was driving around about a month ago and lost oil pressure completely. I decided to pull the engine to root cause the failure and also inspect for further damage. I suspected the oil pump or shaft but these items had less than 500 miles on them. Well, got the engine out yesterday and inspected the oil pump and shaft. They both look perfect so I ruled them out of the equation. Then I found what appeared to be a half inch diameter freeze plug laying in the bottom of the oil pan. It looks as if something went through the center of it and punched it out of the hole it was plugging. It must have made some impact with other moving parts because it is rather mangled. Any ideas from anyone? Could this be the cause of my oil pressure issue. Other than that the bottom end looked decent and I couldn't find any other damage. Please Help!
