no power to anything??
nightster1200
10
i tried to start my car and it fired up and then quit, then i tried it again and i had no power when i turned the key forward, no power to headlights, dashlights anything. is there a main fuse? any ideas where to start.
Check fuses and fusible links.
After that, I would take a look at the ignition switch.
Pic courtesy of Late Model Restoration Supply
  • 64326d1287785504-fusible-link-burned-up-need-help-87-93-5.0-mustang-fuse-links.gif
Check grounds too and make sure you have clean metal connections where they attach. I had some erratic electronics yesterday and a bad ground was the culprit. Like you, the car started, I ran it for a couple minutes then shut it off. Went to start it back up and it was dead as a doorknob.
Voltage drop testing of connections and grounds.
Use a Digital Volt Meter (DVM) to measure the voltage drop across a connection or wire. Adding length to the test leads may be required, and does not affect the accuracy of the test. Use 18-20 gauge wire for the test leads if you have to lengthen them.
Voltage drop testing must be done while the usual load is on the circuit. If it is a starter, it has to be tested while cranking the starter. If it is lights, A/C or fan, they must be turned on high while testing. Fail to do this and you will not get accurate results
1.) Most grounds use the negative battery post as their starting point.
2.) The voltage will be small if the ground is good: less voltage drop = better connection.
3.) Be sure that the power to the circuit is on, and the circuit is being used in its normal manner. For instance, if it is a light circuit, the lights on that circuit should be powered on.
4.) To measure grounds, place one DVM lead on the battery negative post and the other on the wire or connector that goes to ground.
5.) Read the voltage drop: Light duty circuits (1-5 amps) should show .1-.25 volts. Medium duty circuits (6-25 amps) should show .25-.5 volts. Heavy duty circuits (26 amps up) should show .5-.75 volt drop. A voltage drop lower that spec is always acceptable.
6.)
See http://assets.fluke.com/appnotes/automotive/beatbook.pdf for help for help troubleshooting voltage drops across connections and components. .
attachment.php
Have you checked for voltage at points like the alternator, starter, + post on the solenoid? Trace the + battery cable to the + post on the Starter solenoid and start checking voltage from there and then work your way along the wiring.
i think its a ground somewhere, i just turned my key forward and i had power and when i tried to start it, it clicked once, just like a dead battery
Bad grounds can cause some screwy things for sure... Total electrical loss is not usually one of them unless it's the battery terminal. There's more than one ground in the car. If one is bad, you'd still have power to some systems... even if it were erratic.
