No spark please help!!!
mustang88
69
fuel pump turns on but no spark anywhere none from coil either. i hooked up a tach wrong i think(hooked tach green wire to the module clip wire that was green with yellow stripe not knowing i was supposed to connect to coil neg wire instead) no spark anywhere, i dont know what is wrong now, could it be i need a new module or could it be the eec power relay??? i need the car to be running soon due to i ordered a mass air conversion harness and need to install it. help soon please
ok good so maybe its the module? im goin to junk yard tommarow and gunna get everything it could possibly be. what else could it be
oh the first wire i hooked tach to was pip out i found out,car still ran, then came the coil neg wire near distibuter
If you hooked to the PIP, it is VERY easy to fry it (it happens during resistance testing all the time). Once again, if you DONT have injector pulsing, that endorses the PIP being gone. If you do have injector pulsing, your PIP should be fine.
I would NOT go unsystematically tossing parts at it. All you do is create more variables. Spend a few mins diagnosing things.
Just my two cents. good luck.
