no spark @ plugs
  • Thread starter Thread starter skulljab
  • Start date Start date Dec 29, 2006
skulljab
California
Dec 29, 2006
  • Dec 29, 2006
I just got a '68 coupe project, it's got a painless harness and a 5.0 from an '88.
It's got a pertronix ignitor. When I crank it, I get spark at the coil, but no spark at the plugs....Do I have a bad engine ground someplace or what?
I'd appreciate any input.
H
HHStang
566
Coastal SC
Dec 29, 2006
  • Dec 29, 2006
how do you know you have spark at coil?
skulljab
California
Dec 30, 2006
  • Dec 30, 2006
I had somebody crank the engine while I checked for spark out of the coil. I did the same for the plug wires, but I didn't see any arcing. I probably don't have a good enough engine-ground connection.
rbohm
6,698
550
204
tucson,az
Dec 30, 2006
  • Dec 30, 2006
first thing to check is do you have the rotor installed? stupid i know, but even i have forgotten to put it back in, as have others on this board.
second make sure the rotor isnt bleeding spark energy to the dist shaft. you can tell this by looking for a burn mark that goes through the rotor.
skulljab
California
Dec 30, 2006
  • Dec 30, 2006
the rotor is installed and there are no burn marks to speak of.
D
drbobj67
59
  • Dec 30, 2006
This may not be the case since you apparently get spark to the coil, But when I installed the pertonix I had to rewire it from the ignition switch to get enough voltage to the pertronix.
Check this link
http://va-mustang.com/articles.php?articleId=3
skulljab
California
Dec 30, 2006
  • Dec 30, 2006
Thanks alot for the info, I must not have been getting enough power to the ignition; when i thought i had no arcing at the plugs, i was wrong...they had a VERY weak arc. I just didn't notice it. I am going to rewire it and see how things go.
thanks again
D
drbobj67
59
  • Jan 2, 2007
Hopefully that will help let us know how things turn out.
P
Resolved Spark plug location
  • Ptanner
  • May 17, 2026
  • 2024+ (S650) Mustang -General/Talk
2024+ (S650) Mustang -General/Talk May 18, 2026
Ptanner
P
Engine New factory manifold no start
  • Fishnchips
  • Oct 15, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Oct 22, 2026
DadLife0724
F
1986 mustang no start
  • foxyjamss221
  • Oct 11, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 13, 2025
foxyjamss221
F
I
98 Mustang GT dying
  • ItsMason
  • May 14, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 25, 2026
lenzgt
L
Who the hell puts the wrong spark plugs in a 3.8L?
  • snowstang
  • Mar 25, 2026
1996 - 2004 SN95 Mustang -General/Talk- Apr 3, 2026
LILCBRA
