No Spark!
I had this problem too. My coil went bad during the engine swap! I figured it out by simply replacing it and the car then had spark. Also check your TFI module if that doesn't work. MSD goes bad.
I have disconnected the MSD. Didn't matter.
The changes were: H/C/I(2.5-3 months prior)
The car just suddenly died back in september, then sat till 3-4 weeks ago. Replaced the distributor( just old), started right up, shut the car off, went back out in the morning and nothing, just turns.
Went back 3-4 days later and it started right up, WTF!
timing was off so it died, but started right back up then died like I turned off the key, no sputtering.
There is no spark at the coil.
I'm ****ing lost!!
i bought a new dizzy, it was a re-man, but the car idle'd for 3 min's and i shut it off, and no start afterward, come to find out the dizzy shat on me! i brought that pos back. i bought a tfi thinking that was it, nope. i did have to get a blaster coil to fix spark blow out at 5200rpms.
to a search in google on testing the PIP sensor, TFI module and Coil.
Do you have injector pulsing? If you do but you have no spark, the PIP should not be your issue.
Good luck.
