  • 1994 - 1995 Specific Tech
no spout
  • Thread starter Thread starter Ar_sn95
  • Start date Start date Apr 17, 2005
A
Ar_sn95
28
  • Apr 17, 2005
Earlier today I was setting my timing the spout was being pretty stubborn so I had to use a little muscle to get it out when it let loose it went shooting off and now is m.i.a. Just got done spending an hour and a half looking for it and still no luck. My ? Is what will happen if I run no spout and will it hurt the car or drive ability?
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Summerville,SC missing South Fl. weather :(
Apr 17, 2005
  • Apr 17, 2005
It's not going to "hurt" anything you can fashion a paperclip or wire and jump it, that's all the spout connector is a 'jumper'
94TURBO5 O
2,509
VA
Apr 17, 2005
  • Apr 17, 2005
Yeah w/o it you can set your timing up in the 20-30* range for more power. Set is as high as you can in that range as long as you don't ping. You also use the paperclip method as mentioned and that works just fine.
A
Ar_sn95
28
  • Apr 17, 2005
just did it, thanks for the help
HISSIN50
34
129
Apr 17, 2005
  • Apr 17, 2005
and FWIW, a ton of fords use the same SPOUT connector - next time you are at the J/Y, grab one. i doubt they would charge for it even.
i am running locked out right now - i need to put that stupid connector somewhere so i dont lose it.
89MustangGX
I have nothing productive to add!
Jul 3, 2001
10,262
Mill Creek, WA
Apr 18, 2005
  • Apr 18, 2005
You can probably find just about any Ford from mid-80's up and it will have one. Some might look slightly different, but they should fit and work (I've only seen two different types).
fiveotony
1,437
Gainesville, Ga
Apr 18, 2005
  • Apr 18, 2005
I run 32 degrees no spout.
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
L
Electrical issue
  • Landonf00
  • Aug 10, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 10, 2025
Landonf00
L
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
P
2000 GT Random Power Loss
  • Pinellas50
  • Mar 9, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Mar 23, 2026
Pinellas50
P
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
