no start after head gaskets change
blew a head gasket last week, so i did a tear down yesterday.. took everything off, and changed to an f cam why i was at it, put everything back together today. and the focker wont start.
everything goes good, it cranks over fine, but it refuses to fire.
the coil has sparck, as well as the cap. i bought a new one that im changing in the morning. also changed the spark plugs tonight before i called it a night. still the same results.
i pulled a plug out even after changning them, and i got no spark to the plug,, i pulled the wire from the dist., keeping it close to the point, and i could see spark.
could the coil be bad and still be sending spark?
in the AM im going to change teh cap, and see how it goes, if nothing new.. gona buy a new coil as well.
any one have similar experiences with this ****?..or any tips..mucho appreciato
da
I'd check the timing to make sure it's not off because that could be causing it. If your timing is fine then my next guess would be the cam timing. Did you install the cam dot-to-dot? If you are even one degree off your car may not start. This could very well be the problem. Good luck!
yes i intall it dot to dot... i was talkin to sombody and he told me to rotate the distributor 180... ill try that tomottow morning...
I don't know much about the B, F, E or any of the lettered cams, but does it use a H.O. firing order? Do you usually use 15426378? I dunno about the 180 thing. Did all you're fuel stuff go on ok? Do you know if it's lack of fuel AND spark? No you're coil should be good I imagine. All the plug wires clicked on good? Because if you're getting spark from the dist. to the wires you should be getting spark to the plugs. I really think it's bad timing or lack of fuel. All vacuum lines are on good? Sorry, I'm just trying to think of every possible thing. Good luck.
make sure you have the H.O. firing order, not the 1-5-4-2-6-3-7-8.
take the #1 spark plug out and roll the motor over by hand. Roll it over until you feel air rushing out the spark plug hole (asuming your balncer is ok, keep turning until it is at TDC.) pull the cap and make sure it is pointed at number 1, if not pull the dizzy and restab it. That will get you close enough to start it. Just have a timing light ready.
Cranks OK, but No Start Checklist for Fuel Injected Mustangs
1.) Remove push on connector from starter solenoid and turn ignition switch on. Place car in neutral or Park. Remove coil wire from distributor & and hold 3/8” away from engine block. Jumper the screw to the big bolt on the starter solenoid that has the battery wire connected to it. You should get a nice fat blue spark.
A.) MSD or Crane ignition box if so equipped
B.) Coil
C.) TFI module
D.) PIP sensor in distributor
E.) ECC relay next to computer - look for 12 volts at the fuel injector red wires
F.) Fuse links in wiring harness - look for 12 volts at the fuel injector red wires. All the fuse links live in a bundle up near the starter solenoid.
G.) Ignition switch - look for 12 volts at the ignition coil red/lt green wire.
H.) Computer
See the following links for wiring diagrams...
http://www.autozone.com/servlet/UiB..._us/0900823d/80/16/71/3c/0900823d8016713c.jsp for 79-88 model cars
http://www.autozone.com/servlet/UiB..._us/0900823d/80/19/59/5a/0900823d8019595a.jsp for 89-93 model cars
http://www.autozone.com/servlet/UiB..._us/0900823d/80/1d/db/3c/0900823d801ddb3c.jsp for 94-98 model cars
2.) Spark at coil wire, pull #1 plug wire off at the spark plug and check to see spark. No spark, possible failed items in order of their probability:
B.) Distributor cap
C.) Rotor
D.) Spark Plug wires
Two reasons:
Clue – listen for the fuel pump to prime when you first turn the ignition switch on. It should run for 5-20 seconds and shut off. To trick the fuel pump into running, find the ECC test connector and jump the connector in the lower RH corner to ground. See http://www.mustangworks.com/article...c-iv_codes.html for a description of the test connector. If the relay & inertia switch are OK, you will have power to the pump. Check fuel pressure – remove the cap from the schrader valve behind the alternator and depress the core. Fuel should squirt out, catch it in a rag. Beware of fire hazard when you do this. In pinch you can use a tire pressure gauge to measure the fuel pressure. It may not be completely accurate, but you will have some clue as to how much pressure you have.
No fuel pressure, possible failed items in order of their probability:
C.) Clogged fuel filter
D.) Failed fuel pump
E.) Blown fuse link in wiring harness. Look for 12 volts at the Orange/Lt Blue wire on the fuel pump relay. The fuse links live in the wiring harness near the starter solenoid.
F.) Fuel pressure regulator failed. Remove vacuum line from regulator and inspect for fuel escaping while pump is running.
Fuel pressure OK, the injectors are not firing.
A.) A Noid light available from Autozone, is one way to test the injector wiring.
B.) I like to use an old injector with compressed air applied to the injector where the fuel rail would normally connect. I hook the whole thing up, apply compressed air to the injector and stick it in a paper cup of soapy water. When the engine cranks with the ignition switch on, if the injector fires, it makes bubbles. Cheap if you have the stuff laying around, and works good too.
a.) Pull an injector wire connector off and look for 12 volts on the red wire when the ignition switch is on.
b.) No power, then look for problems with the 10 pin connecter (salt & pepper shakers at the rear of the upper manifold).
c.) No power and the 10 pin connections are good: look for broken wiring between the orange/black wire on the ECC relay and the red wire for the 10 pin connectors.
4.) Spark & fuel pressure OK.
A.) Failed IAB (no airflow to start engine). Press the throttle ¼ way down and try to start the car.
C.) Engine ignition or cam timing off: only likely if the engine has been worked on recently).
HO & 351W 1-3-7-2-6-5-4-8
Non HO 1-5-4-2-6-3-7-8
E.) No start when hot - Press the throttle to the floor & try starting it if you get this far. If it starts, replace the ECT.
