  • 1994 - 1995 Specific Tech
NO START ????AGAIN
  • Thread starter Thread starter howiefisher
  • Start date Start date Jun 18, 2008
howiefisher
154
Ont Canada
Jun 18, 2008
  • Jun 18, 2008
so 95 wont start again and i cant even bump start it it still does not start so i have replaced all battery cabels and starter 3 times battery is new i have 12 volts at the power wire on the starter and 12 volts at the igniter wire on crank position but know it wont even start bumping it ??WTF no spark ? i can hear the fuel pump priming ??but when the car did not want to start i removed the negative battery wire and when i went to loosen the main power wire on the starter ,the battery cabel slide back against the battery and my exstention started sparking and the little wire that goes from the neg termanel to rad sadel started smoking like hell could of fried something ??or what about the 2 fusible links ? ps sorry for the long tread
howiefisher
154
Ont Canada
Jun 19, 2008
  • Jun 19, 2008
come on guys need some help ???
earleys94gt
1,223
Ashley, Ohio
Jun 19, 2008
  • Jun 19, 2008
What about the coil?
Have you checked ALL the wiring, battery, coil etc., to see if any if corroded or bare spots?
It sounds like a, no offense, stupid problem like something's not plugged in or connected right.
Good luck.
FlyBy763
439
Palm Bay, FL
Jun 19, 2008
  • Jun 19, 2008
It doesnt turn over at all? Does it click or make any sound when you hit the key?
M
Need help please
  • Mikey62666
  • Oct 12, 2026
2005 - 2014 S-197 Mustang -General/Talk- Oct 14, 2026
gkomo
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
Electrical Code 29 again
  • Creomod
  • Jul 31, 2026
Fox 5.0 Mustang Tech Aug 3, 2026
Creomod
  • dan50
  • Jul 18, 2026
dan50
Electrical Crank-no start ... no spark ... no injector pulse, was it something I did? (redux)
  • 85gtCOBRA
  • Oct 28, 2025
Fox 5.0 Mustang Tech Oct 29, 2025
85gtCOBRA
