It did it again!!!!!!!!!!
Well guess what popped up this morning. No start, pump would not prime. I popped in the new relay....from last time. Nothing....same thing. Ran inside and printed off jrichker's list.
C.) Clogged fuel filter
D.) Failed fuel pump
Since the car sat untouched overnight. I didn't try A. Couldn't check B with the limited time I had this morning and I assumed both relays were bad since neither cut the pump on and neither clicked. I checked E and had 12V.
After looking at both relays: The factory one has 4 pins, and the one from Crapzone had 5 pins. Figured I got the wrong relay. So, I jumped B & E with a spare wire, pump came on and drove to work.
Went to Crapzone, he verified it was the correct relay and had nothing else we could try. He told me to check my oil pressure switch...
Told me the car wouldn't start without oil pressure.
I politely told him that my car doess not have an "oil pressure switch." He still looked it up anyway.
When I left autozone, I put the stock relay back in for S & G. The damn thing works.
So, I have reviewed the wiring diagram and have a few questions.
The only wires I see on the diagram remotely related to the FP relay are:
KAPWR - Fuse link is okay. Measured 12V.
1) Could it be the EEC Relay? No VPWR to FP Relay? Probably not, car ran fine once started.
2) Or is it an issue with the EEC (wire 22)? Wire 22 is a ground...right?
3) Is the inertia switch in-line btw the relay and pump? Or before the relay?
4) Next time it happens, should I measure for 12V at the VPWR terminal on the FP relay? Or should I measure wire 22 at the FP relay? Should be grounded with key on.... right?
Don't know if its coincidence, but it dropped to 27* last night. Might have something to do with cold weather?
Unfortunately, I probably won't be able to troubleshoot this until it acts up again. Just hoping to have a plan in place next time.
