no start
  • Thread starter Thread starter a_turbo_stang
  • Start date Start date May 13, 2004
a_turbo_stang
346
Cincinnati Ohio
May 13, 2004
  • May 13, 2004
Ok I have went through the no start checklist and still nothing.
The car will start up fine when cold. I will drive it across town, turn it off. Then try to start it a few minutes later and it will not start. It is getting fuel and spark. Has a new module on distributer, new distributer, and still does it. Anyone ever have this problem? Any help would be great.
This problem started when I installed GT40 heads, Cobra intake, 24# inj, computer, mass air. These were all installed at once. I am not sure if one of these could cause this or not. But the guy I got these off of never had a problem.
88stangmangt
2,332
Stafford,VA
May 13, 2004
  • May 13, 2004
is your mass air meter for 24lb injectors? if you have fuel and spark i dont know waht else it could be is it throwing any codes?
a_turbo_stang
346
Cincinnati Ohio
May 13, 2004
  • May 13, 2004
yea the mass air is for 24's. No iy is not throwing any codes. It cranks fine but no start. Bout ready to set it on fire, lol
cjones
1,561
Avondale, AZ
May 13, 2004
  • May 13, 2004
when it won't start. can you smell an excess of gas??
try starting it with the gas pedal on the floor.
check for fuel pressure drop. the fuel pressure should hold for at least 60 seconds after shutting engine off.
a_turbo_stang
346
Cincinnati Ohio
May 14, 2004
  • May 14, 2004
Yea you can smell fuel pretty good when it will not start. But it is not leaking anywhere. I will check for a drop.
cjones
1,561
Avondale, AZ
May 14, 2004
  • May 14, 2004
an injector is probably leaking and causing the engine to flood. try starting it with the gas pedal on the floor(flood start) and see if that works.
a_turbo_stang
346
Cincinnati Ohio
May 14, 2004
  • May 14, 2004
Yea holding it to the floor started it. But i tried it a few hours after it had sit and not started. So more and likely I have a bad inj or a few of em bad? Is there an easy way to tell if they r bad?
bjmellon
23
PA
May 14, 2004
  • May 14, 2004
You might also want to check the coolant temp sensor, if it reads too cold it will be fine cold, but crap hot... Does it run ok after it starts
a_turbo_stang
346
Cincinnati Ohio
May 14, 2004
  • May 14, 2004
Yea when it starts it runs perfect.
cjones
1,561
Avondale, AZ
May 14, 2004
#10
  • May 14, 2004
  • #10
after you run it for awhile(so it won't start) wait 10 min. and pull the plugs. the plugs that are wet are where the leaking injectors are.(don't try to start the engine before pulling the plugs or all the plugs will be wet.)
a_turbo_stang
346
Cincinnati Ohio
May 14, 2004
#11
  • May 14, 2004
  • #11
Ok thanks I will try that tomorrow.
HISSIN50
34
129
May 14, 2004
#12
  • May 14, 2004
  • #12
also, if you play with the injectors more, search jrichker's posts if you want. he has written up a nice little test for checking injectors with soapy water. good luck
a_turbo_stang
346
Cincinnati Ohio
May 14, 2004
#13
  • May 14, 2004
  • #13
I will check for some of his posts. Thanks
Will just 1 bad injector make the car not start? Or will I have several bad inj
bjmellon
23
PA
May 19, 2004
#14
  • May 19, 2004
  • #14
Yeah it can, but doubtful. Definitely check for fuel pressure drop.... Another way to check the injectors is by using an injector pulser, and psi gauge to measure the amount of drop each injector has when its pulsed..
L
Engine Why won't the motor start if I have spark and fuel
  • LeviAnderson
  • Nov 20, 2025
Fox 5.0 Mustang Tech Nov 20, 2025
AeroCoupe
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
Engine Random hanging idle
  • 706 Saleen
  • Feb 11, 2026
Fox 5.0 Mustang Tech Feb 19, 2026
86HO5.0
  • dan50
  • Jul 18, 2026
dan50
D
Mustang not starting
  • Dawry Ramos
  • Sep 12, 2026
  • 2015 - 2023 Specific Tech
2015 - 2023 Specific Tech Oct 3, 2026
Dawry Ramos
D
