No Starter Power After T5 Swap
Hey there everyone,
I just finished up a rebuild on my 92 summer special vert, stock displacement, e303 cam, cobra intake, gt40 heads, roller rockers, the whole nine, and swapped to a t5 from an AOD while I was at it (blown AOD was the reason for the rebuild in the first place).
I had a full donor car which apparently also started life as an AOD car as well, which I soon found out when I started pulling things off of it. This led me to sourcing out aftermarket parts. So here is where I sit--
I bought an aftermarket t5 resto/swap harness from late model resto, got it and realized it didn't come with the reverse light pigtail (plug is there for it, just not for the transmission side), installed it anyways, and jumped the clutch safety circuit (overlooked this when buying parts). Problem is I still have no power to the starter in the start position. Hooked up a jumper switch, car started and ran just fine. So my question is this, does the backup light switch also act as a fall back neutral safety switch causing no starter power when it isn't hooked up?
Thanks in advance!
This may help...
No Crank checklist for 5.0 Mustangs
Revised 24-Oct-2013 to update voltage drop figures.
No crank, slow crank and stuck starter solenoid problems have the same root causes – low battery voltage and poor connections. For that reason, they are grouped together.
Use the same initial group of tests to find the root cause of slow crank, no crank and stuck solenoid problems.
Since some of the tests will bypass the safety interlocks, make sure that the car is in neutral and the parking brake is set. Becoming a pancake isn’t part of the repair process…
1.) Will the car start if it is jumped? Then clean battery terminals and check battery for low charge and dead cells. A good battery will measure 12-13 volts at full charge with the ignition switch in the Run position but without the engine running.
A voltmeter placed across the battery terminals should show a minimum of 9.5-10 volts when the ignition switch is turned to the Start position and the starter engages or tries to engage. Less than this will result in a clicking solenoid, or slow cranking (if it cranks at all) or a starter solenoid that sticks and welds the contacts together.
Most auto parts stores will check your battery for free. It does not have to be installed in the car to have it checked; you can carry it with you to the auto parts store.
The battery posts and inside of the battery post terminals should be scraped clean with a knife or battery post cleaner tool. This little trick will fix a surprising number of no start problems.
The clamp on with 2 bolts battery terminal ends are a known problem causer. Any place you see green on a copper wire is corrosion. Corrosion gets in the clamped joint and works its way up the wire under the insulation. Corroded connections do not conduct electricity well. Avoid them like the plague...
If the starter solenoid welds the contacts, then the starter will attempt to run anytime there is power in the battery. The cables and solenoid will get very hot, and may even start smoking. The temporary fix for a welded starter solenoid is to disconnect the battery and smack the back of the solenoid housing a sharp blow with a hammer. This may cause the contacts to unstick and work normally for a while.
A voltmeter is handy if you are familiar with how to use it to find bad connections. Measure the voltage drop across a connection while trying to start the car: more than .25 volts across a connection indicates a problem. The voltage drop tests need to be done while cranking the engine. It's the current flowing through a connection or wire that causes the voltage drop.
See http://assets.fluke.com/appnotes/automotive/beatbook.pdf for help for help troubleshooting voltage drops across connections and components. .
attachment.php
Voltage drops should not exceed the following:
200 mV Wire or cable
300 mV Switch or solenoid
100 mV Ground
0.0V Connections
A voltage drop lower that spec is always acceptable.
2.) Check the battery to engine block ground down near the oil filter, and the ground behind the engine to the firewall. All grounds should be clean and shiny. Use some sandpaper to clean them up.
3.) Jump the big terminals on the starter solenoid next to the battery with a screwdriver - watch out for the sparks! If the engine cranks, the starter and power wiring is good. The starter relay is also known as a starter solenoid.
The rest of the tech note only concerns no crank problems. If your problem was a stuck solenoid, go back to step 1.
4.) Then pull the small push on connector (small red/blue wire) off the starter solenoid (Looks like it is stuck on a screw). Then jump between the screw and the terminal that is connected to the battery. If it cranks, the relay is good and your problem is in the rest of the circuit.
5.) Remember to check the ignition switch, neutral safety switch on auto trans and the clutch safety switch on manual trans cars. If they are good, then you have wiring problems.
Typical start circuit...
attachment.php
6.) Pull the starter and take it to AutoZone or Pep Boys and have them test it. Starter fails test, then replace it. If you got this far, the starter is probably bad.
Starter solenoid wiring for 86-91 Mustang
attachment.php
Starter solenoid wiring 92-93 Mustang or earlier Mustang with upgraded high torque mini starter.
attachment.php
Electrical checks for the switches and starter solenoid
Remove the small red/blue wire from the starter solenoid. Use a screwdriver to bridge the connection from the battery positive connection on the starter solenoid to the small screw where the red/blue wire was connected. The starter should crank the engine. If it does not, the starter solenoid is defective or the battery lacks sufficient charge to crank the engine.
If the starter does crank the engine, the problem is in the clutch safety circuit (5 speed) or Neutral Sense Switch (auto trans) or ignition switch.
See the Typical start circuit diagram above for wiring information for troubleshooting.
You will need a voltmeter or test lamp for the rest of the checks. Connect one lead of the voltmeter or test lamp to ground. The other lead will connect to the item under test.
Look for 12 volts on the white/pink wire when the ignition switch is turned to the Start position. Check the ignition switch first.
No 12 volts, replace the ignition switch.
The next step will require you to push the clutch pedal to the floor (5 speed) or put the transmission in neutral (auto trans) while the ignition switch is turned to the Start position.
Good 12 volts, check the clutch safety switch (5 speed) or Neutral Sense Switch (auto trans) for good 12 volts on both sides of the switches. No 12 volts on both sides of the switch and the switches are defective or out of adjustment. Check the wiring for bad connections while you are at it.
O2 Sensor harness interchange and modification
Originally Posted by 302EFI
Revised 16-Oct-2011 to add O2 sensor harness warnings
The wires for the 02's and low oil did not change throughout the years, they are all in the same place.
The main ones you need to worry about are (on the harness end (ECU) that plugs into the 02 plug) is:
\- 1. Lightblue / yellow
- 2. White / Purple
- 3. Purple / Yellow
The White/Purple & Purple/Yellow gets looped for a automatic ECU
The Purple/Yellow & Lightblue/Yellow for a manual ECU
fox-5-0-o2-sensor-drawing-jpg.529445
Not all wires are shown for clarity and simplicity
See Oxygen sensor Harnesses - Manual/Auto differences and year differences - Ford Mustang Forums : Corral.net Mustang Forum for more O2 sensor wiring harness info
Basic premise to use with transmission swaps:
Only run a 5 speed trans O2 harness with an A9L. Do not run an Auto O2 sensor harness with an A9L. Doing so will damage the computer’s internal signal ground.
Only run an Auto trans O2 sensor harness with an A9P in a car that has an Auto trans. Using a 5 speed trans O2 sensor harness with an Auto trans may cause no crank problems. This has not been verified,
See Computer issue? | Mustang Forums at StangNet for Joel5.0’s fix to the computer internal signal ground.
The 4 cylinder O2 harness uses 4 wire O2 sensors. It probably won’t work correctly without modifying it.
Don't forget the neutral safety switch wire....the thing that keeps the car from starting in gear (automatic) or the clutch switch.
The answer to your question is no.... The reverse harness has nothing to do with starter power. I believe you can go under the dash and source the starter wire...I believe red with blue stripe. Check for power to and from the clutch switch. I run a 95 mini starter with a push button now so the wiring stuff is a little foggy. Summerspecialfox gave some good info. Hope it helps you out.
Thanks for all the replies, a lot of good info and good starting places, thanks jrichker.
Like I said above, I swapped from an aod harness to a t5 harness from LMR, so it should, in theory, kill the neutral start issues all together apart from my lacking a clutch safety switch. I'll chase wires this weekend and make sure I have the low oil switch, and o2 sensors hooked up properly. A lot can be looked over when you are gunnin to fire an engine for the first time in 2 years.
On a side note anyone on the forum running this harness on an automatic ecu? Could this be causing my issues? Worst case I may swap it back to the auto harness and jump the neutral safety circuit for now.
Sorry for the double post still learning the forum,
I would like to add that the clutch safety circuit is already jumped under the dash. One of the first things I did following pedal install without the safety switch itself.
Could you do pics I'm trying to put my fox together. I've got the motor in the wiring is kicking my butt. When I go to start it the solenoid makes a loud thud. Its brand new so is starter. But idk if I have all my wire right or grounds right or if I even have everything. Just some direction or photos of a set up would be nice
Follow the No Crank Checklist I posted, you will find what you need in there.
