No Turn Signals!! Help!!
5.0frank
Hi Everyone. I got a wierd problem with my 89 GT. The turn signals won't work nor the backup lights. I have replaced the flasher, the master function switch, and the fuse. After all that I bought a test light and tested the positive wire going to the fuse and I got no power. I think it might be a fusible link, but I have no idea where they are on my car. Does anyone have a clue as to where they are or what it is. Also, they stopped working when I was driving home at night and all the lights blinked and then went off. I stopped the car and waited a bit and the headlights worked but not the turn signals anymore.
Hope someone can help me.
Ok well since you checked all the things I was going to say, there is one more thing to check. The Ground wires. Look under the dash with a flashlight and there might be a loose ground wire somewhere.
Any fusable links I have seen have been up front in the engine bay.
I got the Chilton's manual, but it did not help me one bit in finding the problem. I look online for some more info. If anyone else has an idea of what it might be please let me know. Also, I do not think it is a ground because there is no power going to the positive side of the fuse, when I ground to the body.
