Noid light on, then flashing - what does it mean?
DREDD_LX93
39
Hey guys, so I'm trying to get my non-starting Mustang to finally start.
I was testing the injectors with a noid light, and noticed the following:
When I turn the key in the ignition to on, the noid light turns on and stays that way.
Then, when I turn the distributor, the noid light flashes.
Now, I've read that while you're trying to start the car, if the noid light stays on or stays off, there's an electrical problem, but if it flashes, it's ok.
My noid light seems to be doing both, so I'm confused. What could this symptom indicate?
I've verified that there's fuel at the injectors cuz I removed the #1 spark plug to check for spark and it was wet with fuel.
Please let me know what you think it might be.
Thanks!
It should do that. The injectors are always hot when the ignition is on, like stangbang302 said. They're grounded through the EEC and pulse that way, so the flashing you see is injector pulsing.
