Noise coming from Serpentine belt/pulley area
Danny1976
Clarksville, TN
Hey everyone! Just wondering if anyone can help me diagnose a small problem with my 2000 Ford Mustang GT (4.6L with 138,800 miles). When I started my mustang lately, there's a sound coming from the serpentine belt/pulley area in front of my engine. It sounds like one of the pulleys are loose or something, but not sure. Has anyone else had this problem before?
  • Sponsors(?)
2002SN95MUSTANG
Charleston, SC
www.myspace.com
What kind of noise is it? Is it coming from left side, right side, or middle? If you have a stethoscope that would be helpful, if not, take a really long screwdriver and place the point on the bolt that holds the pulley on and place your ear on the butt end and listen. If it sounds different than the others, then that's your problem area. Also pull straight up on your belt and check the tensioner. You should have a little movement, but nothing excessive. And now would also be a good time to check the condition of the belt. Check for cracks along the ribs, pieces broken off, and frayed edges. I'll post back if I can think of anything else.
Danny1976
Clarksville, TN
Noise coming from Serpentine belt/pulley area Reply to Thread
Thanks 2002SN95MUSTANG! I'll give the stethascope a try :D
The noise sounds like it's coming from a pulley on the passenger side. As far as how the noise sounds, it sounds like the pulley is loose as it's spinning (like the pulley is rubbing up against some metal surface as it's spinning). The noise isn't very loud, but it's loud enough to be noticeable with the engine running at idle. I'm very seriously considering changing the serpentine belt too, as I have not changed it since owning the car (9 years, 138,800 miles) oops :(
Gearbanger 101
Straight Outta Locash
Super Mod
Aug 10, 2002
9,457
1,376
234
Ontario, Canada
An easy diagnosis and fix. Take the tension off the belt (via a 3/8 ratchet and the belt tensioner) and remove it. Then, reach in and spin all of your idler pullies by hand. If they're loose, or sound like they're full of sand, the bearing is worn out and needs to be replaced as it is likely the source of your noise. While the belt is off, inspect it visually. If there's any noticeable wear, rips, or cracks in the belt, replace it. If not, put on a pair of rubber gloves, get yourself an old pickle bucket and go to town on it with a scrub brush, some scalding hot water and some Ivory dish soap.
While the belt is off, this would be a good time to inspect your water pump and power steering pump to ensure they're not leaking and leaving any residue on the belt.
Assuming all is well with the other components, reapply the belt (or install the new on if necessary), start it up…bring it up to operating temperature and take if for a ride.
Danny1976
Clarksville, TN
Thanks Brian! Will try that too! It might be a loose pulley or something like, hopefully. If so, it sounds easy to fix.
sneaky98gt
2,387
144
114
NC State University
Yea, what Gearbanger said. Mine did this back in the summer. The bearing in my tensioner pulley was going out. You can't just replace the bearing; you actually have to replace the entire pulley. I went ahead and replaced the tensioner pulley, idler pulley (the 2 are the same size, or at least on my Romeo motor), and the belt. Haven't heard a peep since.
-Will
Danny1976
Clarksville, TN
Thanks Will!
Could I get the new pulleys at an auto parts store or do I have to order them online from a manufacturer?
Thread starter Similar threads Forum Replies Date
K HELP! Nasty Grinding noise coming from center of the engine/ Mustang 06 v6 2005 - 2014 Specific V6 Tech 1
derek2079 Can anyone tell me what noise this is coming from my engine bay? VIDEO INSIDE 1965 - 1973 Classic Mustangs -General/Talk- 7
S Reoccurring squeak/chirping noise coming from rear. SN95 4.6L Mustang Tech 1
S Weird noise coming from under the middle of car? 01 Mustang GT 1996 - 2004 SN95 Mustang -General/Talk- 2
O Drivetrain Noise coming from transmission? 2010 - 2014 Specific Tech 0
A 2006 ford mustang v6 ticking noise coming from engine 2005 - 2014 Specific V6 Tech 1
M Consistent BBQ Ticking noise coming from engine 2015+ (S550) Mustang -General/Talk 2
R Noise coming from rear left wheel. Getting mixed information from facebook 1996 - 2004 SN95 Mustang -General/Talk- 1
C New Gt Owner! Bad Noise Coming From Drivetrain Behind Engine. Fox 5.0 Mustang Tech 7
W Engine 98 Ticking Noise (comes And Goes) SN95 4.6L Mustang Tech 1
zhendo95 Strange Knocking Noise Coming From Front End. Help!!! SN95 4.6L Mustang Tech 0
old_blue Lets play, whats that noise and where is it coming from. 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 5
S Engine 2000 GT 4.6 V8 Noise coming from Pulleys... how to (pic attached) SN95 4.6L Mustang Tech 5
HuskerNation Whirling noise coming from front of Engine. (Video) Fox 5.0 Mustang Tech 3
Z Weird Noise Coming From Gauges Fox 5.0 Mustang Tech 3
9 98 cobra - noise coming from front SN95 V6 Mustang Tech 2
9 98 cobra - noise coming from front SVT Tech Forum 3
94stangfan Weird Noise coming from engine bay 1994 - 1995 Specific Tech 4
5 Odd Noise Coming From Front Of Car... SN95 4.6L Mustang Tech 9
sn95jones Noise Coming From Transmission SN95 4.6L Mustang Tech 5
Rasikajay Weird clicking noise coming from dash SN95 4.6L Mustang Tech 9
W Noise coming from my transmission.... 2005 - 2014 S-197 Mustang -General/Talk- 12
W There is like a rubbing noise coming from the suspension 2005 - 2014 S-197 Mustang -General/Talk- 6
M Grinding/Clicking Noise Coming From Front End SN95 4.6L Mustang Tech 11
c.moser LOUD tapping noise coming from valve train... SN95 4.6L Mustang Tech 20
Y Gurgle Noise coming from Air Intake tube...Help Please SN95 4.6L Mustang Tech 6
LarsD Have a groaning-type noise coming from my SN95 brakes, what is it? Fox 5.0 Mustang Tech 8
N Noise coming from distributor area? 1994 - 1995 Specific Tech 16
K Popping noise coming from under strut bearing bracket? 2005 - 2014 S-197 Mustang -General/Talk- 7
3 Got This Noise Coming From My Rear .... Fox 5.0 Mustang Tech 4
89GT331 Strange Noise coming from rear? Fox 5.0 Mustang Tech 1
B Rapping noise coming from driver side dashboard SN95 V6 Mustang Tech 0
No.11 Grinding Noise coming from ebrake area Fox 5.0 Mustang Tech 4
K Growling noise coming from the intake? Fox 5.0 Mustang Tech 9
lazy_stang Loud noise coming from rear speakers on Mach460 Mustang Sound & Shine All 3
M squeaking/chirping noise, not coming from pulleys? SN95 V6 Mustang Tech 6
Sinister SN95 Grinding/rubbing noise coming from my rear end~~ SN95 4.6L Mustang Tech 8
deftsound Wining noise coming from speakers, need help! 1994 - 1995 Specific Tech 5
I Loud ticking noise coming from Intake Runners Fox 5.0 Mustang Tech 2
1 loud noise coming from water pump area 1994 - 1995 Specific Tech 6
M ringing noise probably coming from rear SN95 4.6L Mustang Tech 27
C Noise coming in on Mach460/aftermarket HU Mustang Sound & Shine All 13
mrvax Is this noise coming from my tranny? 1996 - 2004 SN95 Mustang -General/Talk- 4
D noise coming from rear end SN95 4.6L Mustang Tech 0
georgio440 Annoying squeeking noise coming from the front suspension... SN95 4.6L Mustang Tech 13
04YELLOWGT Blower Guys Come In (Weird Noise) SN95 4.6L Mustang Tech 2
Bullitt95 Wierd noises coming from under my car 1994 - 1995 Specific Tech 6
The Green GT Noise coming from under the car... 1994 - 1995 Specific Tech 16
G Roush Rattle noise coming from the blower? Special Production 2
C Weird noise coming from under the hood Fox 5.0 Mustang Tech 5
