NOISE...DETONATION??
I think my car is having a similar problem...
Except, I only notice mine "pinging" in gears other than Park or Neutral.
Am I missing something here :shrug:
Just put new heads on, so no carbon.
Maybe a bad fuel injector???
Detonation will not occur without load.
More info would be required. That said, low octane, a large vac leak, a MAF issue, running lean for other reasons, and about 20 other things could lead to detonation.
My timing is between 10-12*, so I run 87 octane.
The engine was just put back together w/ new gaskets/seals.
The MAF is stock but I check it regularly for cleanliness.
I did pull my plugs, and #'s 3 & 7 were bright white.
Usually means a lean condition.
I am going to buy new plug wires and a fuel filter.
Try some "cheap" and easy things first, then go from there.
