  • 2005 - 2009 Specific Tech
noise from wheelwell
  • Thread starter Thread starter TestMe
  • Start date Start date Mar 22, 2009
T
TestMe
28
Lubbock TX
Mar 22, 2009
  • Mar 22, 2009
I am hearing noise from my wheel well when i turn my wheels. It just started a couple of weeks ago and doesnt do it all the time so i know its now my wheels rubbing. Anyone got any suggestions on what could be causing this?
C
COBESGT
231
Dubuque, Iowa
Mar 23, 2009
  • Mar 23, 2009
If you notice the sound only when the wheels are turned, it could be a wheel bearing. Jack-up the front end and give each wheel the push-pull/spin test.
1. Put your hands at the 3 and 9 position and try to move (push and pull) the wheel in-out. If there is movement, it could be an inner or outer tie-rod. I doubt this is the case as you would hear/feel this all of the time.
2. Put your hands at the 12 and 6 position and try to move (push and pull) the wheel in-out. If there is movement, it could be a bad ball joint. I doubt this is the case as you would hear/feel this all of the time.
3. With the wheels up in the air, give them a spin. Do you hear any grinding noise or does the wheel not spin freely? If either exist, then suspect you have a bad bearing. Normally a bad bearing can be heard pretty easily when you are driving and going around a corner or at slow speeds when making a sharp turn.
Hope this helps.
klaw
343
Calgary, Alberta, Canada
Mar 23, 2009
  • Mar 23, 2009
I see you have 20's - are you showing a TPMS failure by any chance? I had a TPMS band break in my 20's which caused a metal rattling sound at low speed. Some of the aftermarket bands that came out for the bigger wheels were complete crap.
SCJSTU
26
Georgia
Mar 24, 2009
  • Mar 24, 2009
I have 20's and had a noise when turning the wheel.......turned out the upper strut tower bushing/bearings were bad.....maybe because of the bigger rims?
car just turned 40k
H
Aluminum timing chain guides ?
  • healy1963
  • May 5, 2026
2005 - 2014 S-197 Mustang -General/Talk- May 5, 2026
healy1963
H
Brakes Front Brake Hardline Routing
  • 93Nifty
  • Sep 11, 2026
Fox 5.0 Mustang Tech Oct 11, 2026
limp
D
2006 Roush Stage 2 Mustang Chin Spoiler/Lower Grill Inserts Needed
  • DG_Damn_Good
  • Oct 13, 2026
  • The Welcome Wagon
The Welcome Wagon Oct 14, 2026
DG_Damn_Good
D
G
Electrical Getting good ground in 1991 Fox Vert for amps - getting popping noise when I turn on the lights?
  • gvanginkel403
  • Apr 11, 2026
Fox 5.0 Mustang Tech Jul 21, 2026
gvanginkel403
G
92 5.0 almost starts
  • Steverino
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 25, 2026
General karthief
