Noise when cold...
cardinales15
T3650 Odd Noise when cold...
I did some searching but I can't seem to find anything closely related to the noise I hear from my 2003 GT. Before the engine and trans get up to temp in the morning I have this low pitched whine similar to the sound of the heat blower motor (no the heat/AC is not turned on) coming from around my shifter. It only happens when the car is going 55mph or higher in 5th gear and is above/beyond the normal manual tranny whine. This louder whine/sound goes away after the car reaches normal operating temps. There doesn't appear to be any mechanical difficulties when shifting, the tranny is quite smooth. The clutch works fine, then noise is present with the clutch engaged and not engaged. It also goes away when I am below 55mph. Any thoughts?
2003 GT 5spd
CAI, O/R Prochamber, flowmaster catback, 4.10s and MGW shifter.
48k
Oh...and it was about 40 degrees this morning when I fired her up and took off.
Thanks
