Noisy Rear End
  • Thread starter Thread starter MikeR351w
  • Start date Start date Sep 9, 2004
MikeR351w
207
Wisconsin
Sep 9, 2004
  • Sep 9, 2004
I got a 92 Mustang with an alluminum driveshaft. It is an auto trans. When I accelerate slowly in 1st gear, i hear a whine comming from the rear. As soon as it shifts into second, it disappears. But then I have a much quieter whine that sounds like a humming, but no vibration is felt. When I slow down and allow the trans to downshift the driveshaft jerks a little and makes the car jerk as well. Then rear is a 3.27 posi and it is stock. What could it be?? The drive shaft does have some small dents and suck on it. Nothing huge though.
D
Daggar
3,902
  • Sep 9, 2004
I doubt that it's your driveshaft and your description doesn't make me think U-Joints. My guess is that your ring and pinion gears are worn. May be time to go ahead and have those 3.55s you've always wanted installed.
Legendary
1,925
City of Angels
Sep 9, 2004
  • Sep 9, 2004
Like said it could be your gears or maybe your fluid is pretty old or leaked out. If it's worn gears I would be ready to add some 3.73's. (maybe 4.10's since you have an aod)
MUSTANGJOE
Silver Stanger
1,644
17
59
Sep 9, 2004
  • Sep 9, 2004
check your diff bolts to make sure its not loose.
M
Meangene21
187
Chesterfield VA
Sep 9, 2004
  • Sep 9, 2004
Okay man here we go.
I just had this problem with my 4.10's we installed.
When installed WITHOUT SHIMS (behind the pinion) we heard a nice whine sound and tumble sound. When putting it into gear it would go in not as smooth as before. When down shifting it would really whine and make almost like a clunk noise.
Here was the problem.. With no shimes the Pinion was not spaced correctly. So under excelartion it had the correct angle,(thus just a little bit of whine) but under de-celeration the pinion would almost bounce around (because it was loose and not fully tight). We thought it was the gears.( Because the old 3.55's had no shimes). Bought Richmond 4.10's same problem. So after talking with several people we found out the following......
Ford gears are shimed on the Pinion. Not a very large amount, we ended up putting in a .17 Shim and a .13 behind the pinion and infront of the bearing. Installed the pinion and gear.. When rotating the wheels it was WAY too tight. So we removed the shims and added a .24 shim. Rotated the wheels and they moved as they should.
As soon as that was done and adding ALL that damn fluid in AGAIN (3rd time), i started rolling. NO WHINE NO TUMBLE SOUND AT ALL !!!
So you might wanna make sure you spaced the pinion correctly.
( i hate the smell of Rear End Gear Oil )
Progress Thread The Mach Returns - Update/build thread
  • squeak93
  • Feb 20, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 19, 2026
squeak93
Wheels-Tires LS mii swap and rear rim size/axle questions....
  • 78mIIman
  • Feb 2, 2025
1974 - 1978 Mustang II Talk & Tech May 6, 2025
78 Mach1
Engine Bad vibration 3500 RPM+
  • Vulpes5.0
  • Sep 8, 2021
7K
Fox 5.0 Mustang Tech Sep 22, 2021
Vulpes5.0
Drivetrain Rear end popping noise
  • sav22rem22
  • Jan 29, 2021
2K
Fox 5.0 Mustang Tech Feb 3, 2021
sav22rem22
A
1995 5.0 Issues
  • Andre6
  • Nov 24, 2021
  • 1994 - 1995 Specific Tech
4K
1994 - 1995 Specific Tech Jan 9, 2022
90sickfox
