hydraulic lifters are taller than the solid lifters, on non-roller blocks, the lifter bore is not as tall as it is on roller blocks. so if you use standard hyd lifters in a non-roller block with a standard base circle cam, you run the risk of pushing the lifters too far out of their bores and spinning out of alignment so that they would not go back down, which would of course be very bad.
youo can use a smaller base circle cam which would drop the lifters further down into the bores, but cams like that are not recommended, not 100% sure of the reason, something about the angles not being good because of the smaller base circle.
link bar lifters are shorter than reguar hyd lifters, and they cannot get out of alignment, and they let you use standard base circle cams, so they are the "right" way to go, but they are very expensive.
