  • 1994 - 1995 Specific Tech
noob changing plugs
  • Thread starter Thread starter sade04
  • Start date Start date May 11, 2006
sade04
97
Lansdale, PA
May 11, 2006
  • May 11, 2006
how in the world do you guys get to the #4 plug??? i cant even get my hand in there to pull the wire boot off. help!
drakesdad
961
Oregon OHIO
May 11, 2006
  • May 11, 2006
I have seen guys remove the plastic trees and pull the inner fender plastic to get to it.......swivel sockets are "wonderful"
Therian
The Highlander
Waterloo, Ontario
May 11, 2006
  • May 11, 2006
get smaller hands...
BlackVert
5,589
9
98
Bethesda, MD
May 11, 2006
  • May 11, 2006
that's the one behind the egr valve right? i take the valve out - it is much easier then
The Green GT
No 13 year olds are safe around me.
1,269
Louisiana
May 11, 2006
  • May 11, 2006
Hire a contortionist. Seriously though, Its a PITA, just keep trying, I tried for about an hour the first time I had to take them out.
dstanggt50
1,316
Woodinville, WA
May 11, 2006
  • May 11, 2006
same here, I take the tube that goes from the egr to the headers off, and take some of those smog hoses off. Usually makes it easier, and not to hard to take off. Good luck.
SeventyMach1
Keep it lubed .... keep it straight .... and keep
Mar 30, 2005
1,940
North Carolina
May 11, 2006
  • May 11, 2006
Remove the smog stuff! (if you can in your area) It makes them much easier to access. I've never had an issue with the EGR tube, though.
Even when I DID have smog on my car ..... swivels and extensions proved to be the best and quickest way possible.
sade04
97
Lansdale, PA
May 12, 2006
  • May 12, 2006
remove the smog stuff? do you guys know if PA requires it?
SeventyMach1
Mar 30, 2005
1,940
North Carolina
May 12, 2006
  • May 12, 2006
Not sure. But if PA is like NC .... it's all "county-specific".
Best bet is to check your local laws if someone doesn't chime in to let you know. There should be a website available to tell you .....
urban96
bubb rubb says:"woo woooooo"
3,464
Syracuse, NY
May 12, 2006
#10
  • May 12, 2006
  • #10
not sure if you did this or not but it makes it 10X easier if you remove the intake tubing. atleast then you can see in there
MysteryMachine
1,835
Parkesburg, PA
May 12, 2006
#11
  • May 12, 2006
  • #11
Most likely you need it. Places the didn't need it before are going to it so you better ask first
GRGT1994
1,034
#12
  • May 12, 2006
  • #12
I believe I have read others from PA posting that their state is very strict on emissions.
1TallMF
955
Montreal
May 12, 2006
#13
  • May 12, 2006
  • #13
I just removed the intake tube and the smog hose assembly by untightening 3 hose clamps. Then with a swivel and a whole lot of extensions, yo can get to the plug without any major effort. Didn't have a problem with the egr tube when I did it though.
Zero Signal
2,633
Tucson, AZ
May 12, 2006
#14
  • May 12, 2006
  • #14
I always remove the intake tube and smog crap and, with a universal on the socket, I've never had an issue changing the plugs.
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Summerville,SC missing South Fl. weather :(
May 12, 2006
#15
  • May 12, 2006
  • #15
You guys go through alot of crap.....Spark plug wire pliers, extention, swivel, and you're done.
Therian
The Highlander
Waterloo, Ontario
May 12, 2006
#16
  • May 12, 2006
  • #16
ditto...most I've ever taken off was the cold air assembly from the maf to the tb.
  • Mindseye007
  • Aug 16, 2026
Mindseye007
M
Idle control problems
  • miser143
  • Aug 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 29, 2026
DadLife0724
96 GT 4.6 w/ dirty spark plug well
  • Mustang Momma
  • Apr 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Apr 9, 2026
LILCBRA
Crank no start on a turbo and cammed pushrod 5.0
  • 1630stri
  • Sep 2, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Sep 16, 2026
Qtrhrse23
Help Identifying Engine Harness Plug
  • FoxbodyRob
  • Feb 7, 2026
  • 2.3L (N/A & Turbo) Tech
2.3L (N/A & Turbo) Tech Feb 7, 2026
FoxbodyRob
