  • 1994 - 1995 Specific Tech
Normal Oil Loss????
  • Thread starter Thread starter Adam95GT
  • Start date Start date Oct 25, 2006
Adam95GT
2,564
Burlington, NJ
Oct 25, 2006
  • Oct 25, 2006
Well... just put 2200 miles on the stang from the last oil change... i just hit the add line... is this normal oil loss in a stang??? it does look a little dark... and ive been a little hard on the motor... but for 205k that doesent seem bad... OH and im still using 5w 30 in it...
HISSIN50
34
129
Oct 25, 2006
  • Oct 25, 2006
Is all of the loss from burning or any from leakage?
Assuming it's from burning, that's not all bad considering that some of the driving was likely during hotter weather and you ran 5W oil.
I might run 10W-30 next summer if the rate of consumption slows over the winter.
Good luck.
Adam95GT
2,564
Burlington, NJ
Oct 25, 2006
  • Oct 25, 2006
i actually thought thats not bad at all... there is not any leaks but still... i still wanna use the 5w30 because thats what the previous owner used the whole time he owned the car its running well so im gonna follow the trend. to me this means that the car has alot of life left in it. whats it from the add line to the full line 1quart??? and what are you suposed to put in every oil change... i never checked... i figure its around 5 i think i put about that in last time
HISSIN50
34
129
Oct 26, 2006
  • Oct 26, 2006
It should be one quart from low to high, though I have not checked it (after some of the fox dipsticks were mismarked, I think they got it right for the SN95's).
Yep, 5 quarts of oil with pulling both drain plugs and a standard (FL1A) filter.
Adam95GT
2,564
Burlington, NJ
Oct 26, 2006
  • Oct 26, 2006
both drain plugs... i might of missed something...
95opal
5 Year Member
Nov 16, 2004
449
20
39
Oct 26, 2006
  • Oct 26, 2006
yes we have two plugs one towards the rear of the pan and one towards the front of the pan, you need to drain both.
94-302-vert
1,947
NE CT
Oct 26, 2006
  • Oct 26, 2006
After about 1800 miles I put in one quart so I say within range for the entire oil change...
parchisi
519
New Mexico
Oct 26, 2006
  • Oct 26, 2006
With my engine:
forged pistons + rear main leak = about 1 qt per month
1TallMF
955
Montreal
Oct 26, 2006
  • Oct 26, 2006
Yeah, that front plug boggled me the first time I changed the oil. That had me freaked out when I pulled the front plug and all that came out was like 6oz of oil. I'm sure Ford could have engineered the oil pan a bit differently. Oh well.
I go through maybe 1/4 - 1/2 quart every 3000 miles or so, thats Mobile 1 10W30 (previous owners ran this its whole life). I think its got at least another 100k miles left in it.
R
Engine Evap and charcoal cannister leak
  • ryan1994stang
  • Mar 14, 2026
Fox 5.0 Mustang Tech Mar 18, 2026
Mcmahst
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
P
Is it normal for all of this to go wrong or did I get played when I bought this ONLY A MONTH AGO.
  • ponygal02
  • Nov 14, 2025
1996 - 2004 SN95 Mustang -General/Talk- Nov 14, 2025
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
Engine New Oil Leak Help.
  • Slo5Oh89
  • Mar 14, 2025
Fox 5.0 Mustang Tech Mar 19, 2025
Slo5Oh89
