Not able to pull codes
  • Thread starter Thread starter afast93stang
  • Start date Start date Oct 8, 2004
afast93stang
1,407
North Texas
Oct 8, 2004
  • Oct 8, 2004
I have a Actron scanner for Fords, when I try and read the codes it doesn’t seem to download them. I have gone through the steps many times, waited up to 10 minutes for the codes to download and still nothing. The manual says it should get them in 10 seconds to a minute. I have also tried going to AutoZone but they said they don’t pull codes on cars made before '96. I’m not sure what else to do besides taking it to a shop and having them do it but I would rather save that money...
The problem I’m having is my check engine light is on, it smells like I’m running rich and on mornings colder than 70* out its hard to keep running for the first minute or so, but once it warms up its good for the rest of the day.
I have recently changed plugs, wires, cap and rotor, O2 sensors, egr sensor, reset the timing to 10*, and checked TPS too.
What else can I do?
A
autoXr1
1,838
Michigan
Oct 8, 2004
  • Oct 8, 2004
Let me ask this. When you initiated the KOEO self-test, did you hear the fuel pump turn on for a few seconds and a few "clicks" of the various actuators? If not, you likely have an open ground somewhere. Take a piece of 12-16ga stranded wire, strip about 3/8" of the insulation off either end. Stick one end into the small test connector on your harness (next to the large test connector where you plug in your Accutron scanner), and the other end to a good chassis ground. Try it again. If you've got a "check engine" light, it's likely you've got codes that'll trigger.
After that, beef up your electrical grounding system. http://www.stangtuning.com/showthread.php?t=1656
afast93stang
1,407
North Texas
Oct 8, 2004
  • Oct 8, 2004
The fuel pump does its normal priming sound and there are no clicks after that.
Ill try the ground thing, thanks for the great info
Ourobos
260
Oct 8, 2004
  • Oct 8, 2004
Wow, I just put a stock motor back in my LX, and the scanner does the same thing. I get a few click up near the engine though. It pulled codes fine before the swap, so I am hoping for a ground problem. Thanks AutoXr1
Engine Vacc leak detector
  • Creomod
  • Jul 19, 2026
Fox 5.0 Mustang Tech Jul 25, 2026
Mustang5L5
Engine Code 41 again
  • Creomod
  • Jul 7, 2026
Fox 5.0 Mustang Tech Jul 11, 2026
Mcmahst
Electrical Code 29 again
  • Creomod
  • Jul 31, 2026
Fox 5.0 Mustang Tech Aug 3, 2026
Creomod
W
Engine My engine dies after running 10 to 15 minutes under high heat.
  • Wylieone
  • Jun 21, 2026
Fox 5.0 Mustang Tech Jun 22, 2026
Mustang5L5
Engine Keeping O2 sensors lit with long tube headers
  • keel
  • Jul 30, 2026
Fox 5.0 Mustang Tech Aug 21, 2026
Qtrhrse23
