Not Another Ram Air Thread!
93gtmustang
524
43
49
A person at the track suggested this.
Is there any gains by running something like aluminum flexible dryer hose from your fog light opening to your stock air box on a 93 GT Mustang.
This would be strictly for drag racing purposes only.
I have read that you have to be going at least 70mph to get any ram air effect.
I'm hitting 82mph at the 1/8 mile and 102mph at the 1/4 mile finish line.
Anyone ever do this?
What where the results?
Or is this just plain stupid!
Thanks
Well ram air does work but I thought it was closer to 100mph before it sees any real gains. I could be wrong. That being said such cars as the thunder bolt used ram air setups to help with any little edge in drag racing back in the 60's.
There are those who say it is worthless but don't show any test data to prove it. I believe that even if all ram air does is decrease vacuum then it is helping. I have recently read an account that showed a 1 psi boost using ram air at speed.
If nothing else, a good ram air setup is a guaranteed cold air intake since the air is definitely coming from OUTSIDE and nowhere else....so even if the ram air effect doesn't really help until high speeds you can at least count on that.
the force --> pressure calculations would be pretty quick and easy to do. However, you would need to know the volumetric flow rate through your engine at WOT. When the flow rate of air is greater than the max flow rate of your engine then you would be seeing "boost" If i had the time, I would do this real quick b/c I'm interested. Maybe someone else has some spare time?!
