Not sure if motor is blown or not.. help plz
  • Thread starter Thread starter savegoodautonfg
  • Start date Start date Apr 21, 2006
savegoodautonfg
1,085
  • Apr 21, 2006
OK. i'm driving on the thruway yesterday around 3 in new york and all of a sudden my car made a huge knocking noise and the car died completely.the noise was to the point where it sound like a bearing broke in my short block and is knocking around in my engine it sounds sooooo bad i can't even drive it its not even funny. well im not totally positive what it is but i think the motor is blown. please give opinions or ideas.
I really would appreciate it.
RBRANDX
110
Myrtle Beach, SC
Apr 21, 2006
  • Apr 21, 2006
Dude....Sorry to hear that, but I think we have all been there before! If the noise is as bad as you say, and is coming from the bottom end, you can bet its serious. Could be a number of different things...but the only way to find out for sure is to open it up and see...Probably not the answer you want, but it is the only way to find out for sure....On a positive note it does afford you the oppertunity to beef up your short block for future mods....Good luck.
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Apr 21, 2006
  • Apr 21, 2006
sounds like you are going to hae to pull t and have a look. did you lose oil pressure?
Jozey
127
Tucson,AZ
Apr 22, 2006
  • Apr 22, 2006
savegoodautonfg
1,085
  • Apr 23, 2006
See im only 18 yrs old and im just learningabout cars and i bought this mustang last year. i have no idea how to open an engine up
RBRANDX
110
Myrtle Beach, SC
Apr 23, 2006
  • Apr 23, 2006
Buy a Haynes of Chilton repair manual ( you WILL need this eventually!) , recruit a couple friends, and get busy. You will gain invaluable experience by teaching yourself...you may not get things right the first time around, but as soon as you get everything put back together and running right I promise you will be pretty damn proud of yourself! And next time something goes wrong ( and it will) you will be able to know your way around. Just be patient, take your time and dont be afraid!
txstang84
1,639
42
69
Tuscola, tx
Apr 23, 2006
  • Apr 23, 2006
savegoodautonfg
1,085
  • Apr 25, 2006
Well a few hours ago i go outside and pop my hood and my serpentine belt is off i put it back on and start the car and metal pieces small are on the ground. i get under with a flashlight and i see that behind the crankshaft it is cracked and thats where the metal pieces are coming from.
What does this mean?
savegoodautonfg
1,085
  • Apr 25, 2006
bump please help
91lxttrim
194
AZ
Apr 25, 2006
#10
  • Apr 25, 2006
  • #10
Do you mean behind the balancer (with the timing marks)? If so, anything that has 'cracked pieces of metal' can't be good.
See if you can find a low miles engine out of another wrecked Stang. Then you can play around with your block (if it's any good).
I broke a cam once and didn't know what it was until I tore the engine apart. That's all you can do sometimes...
Good luck man, and hopefully you can learn alot from it.
1991vert
1,103
Ludlow, MA
Apr 25, 2006
#11
  • Apr 25, 2006
  • #11
im with everyone else. i had valve float once, and the lifter moved to the side of the pushrod and it was slapping my valve cover for about 1/2 mile, then stopped cuz the rod bent and got wedged in the lifter valley, but it wouldn't cause the car to die out.
i think it's time to learn by taking it apart and putting it back together, skippy.
L
livinitup1
vineland n.j.
Apr 25, 2006
#12
  • Apr 25, 2006
  • #12
blown engine
My first 306 i built lasted a year with a stock ground crank car would run like crazy. one day i was playing around and romped on it . car took off then died. coasted to a gas station opened hood serp belt was broke and oil all over ground further inspection revealed crank busted at #1 journal and busted block, pully hanging by front seal . talk about dissapointing but that led to a 347 stroker and a sportsman block that will melt tires in 3rd gear. moral of story there can be a positive side to a blown engine.
savegoodautonfg
1,085
#13
  • Apr 28, 2006
  • #13
Also about the crankshaft It also moves left right and in and out?
I
Iand
50
Kelowna, BC
Apr 28, 2006
#14
  • Apr 28, 2006
  • #14
No matter how you look at it, your gonna probably have to get a new block or rebuild...if your lucky. Im in the same boat as you, my engine just went 4 weeks ago, 2 broken pistons, in the process of rebuilding. First rebuild but iv learned a TON so far.
K
Engine 2000 Mustang GT - Fuel issue post-blown spark plug repair
  • kenster1092
  • Feb 26, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Mar 10, 2026
kenster1092
K
Drivetrain Fox Power Loss While In Gear
  • J_5.0_VERT
  • Dec 17, 2024
Fox 5.0 Mustang Tech Dec 31, 2024
J_5.0_VERT
Engine Throwing codes 94, 33, 34, 44, and sporadic engine shutoff.
  • Ryu
  • Oct 9, 2024
Fox 5.0 Mustang Tech Sep 13, 2026
Help with window and possible engine
  • StefRena22
  • Jun 12, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2025
Willybill32
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
