Notching pistons???
  • Thread starter Thread starter Sick5.0
  • Start date Start date Aug 24, 2005
Sick5.0
  • Aug 24, 2005
is there a good way to do it while they are still in the motor???
giddyup306
3,041
Aug 25, 2005
  • Aug 25, 2005
Dremel. Be VERY careful about removing ALL debris.
Rick 91GT
Mustang Master
95
99
PA
Aug 25, 2005
  • Aug 25, 2005
I made a custom fixture to do the pistons while they are in the motor, in the car...I also made the custom cutters, however ISKY does sell a cutter that uses your head.
bock
648
Montreal,Qc
Jun 14, 2006
  • Jun 14, 2006
how do you no when you have made enough space?
and how about pistons balance?
smittyb
134
Marysville,wa
Jun 14, 2006
  • Jun 14, 2006
Do you have new heads to go on it?
M
Marlboro_Man
437
Houston, TX
Jun 14, 2006
  • Jun 14, 2006
Thats what i'm wondering too.
smittyb
134
Marysville,wa
Jun 14, 2006
  • Jun 14, 2006
Alright, you can use your old heads and an old valve to do the notching. Just cut teeth into the valve with an air cut off wheel. Bring the piston to be notched to TDC, put the modified valve ion the head, bolt it on, and chuck up the valve stem in a drill. As far as knowing how far to go, just keep checking. You should have some idea how far you need to go before you begin. Then just keep setting up your valvetrain and checking till you get there. Once you have the first cylinder done, you can make a mark on the valve stem and simply go to that depth on the others. You should remove the valve seals first, as they can be at different heights. The reason I asked if you have new heads, is you are gonna need new valve seats for sure.
How's that?
bock
648
Montreal,Qc
Jun 15, 2006
  • Jun 15, 2006
if you go with 2.02 and 1.60 valves in tw,can you do this with the stock heads and valves?
smittyb
134
Marysville,wa
Jun 15, 2006
  • Jun 15, 2006
If you are trying to ask if you can notch pistons for use with TW heads using your stock heads, the answer is no.
Rick 91GT
Mustang Master
95
99
PA
Jun 17, 2006
#10
  • Jun 17, 2006
  • #10
I think your asking since the large valevs fit with a TW can you do it with a stocker? Well you can not put a 2.02 valve in a stock head, plus the larger valve will kill the flow of that small head.
The TFS fits since the valve location is Twisted, which moves it away from the centerline and actually allows for a slightly larger cam to be used.
bock
648
Montreal,Qc
Jun 17, 2006
#11
  • Jun 17, 2006
  • #11
OK.
My tfs TW are ported and i think they need more cam than the f-303 that i have now.my shortblock is 100% stock.
Thats why im asking...
L
T5 compatibility on a 81 notch
  • lench23
  • Nov 10, 2026
  • The Welcome Wagon
The Welcome Wagon Monday at 2:17 PM
KRUISR
G
Engine ECU Question
  • GeorgeE
  • Oct 12, 2026
Fox 5.0 Mustang Tech Oct 19, 2026
JD1964
F
86 notch NEED HELP!!!!
  • foxbody86
  • Jul 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 9, 2026
Drivetrain Tail Shaft bore odd shape
  • R82148V
  • Jun 12, 2026
Fox 5.0 Mustang Tech Jun 13, 2026
Mustang5L5
D
Electrical Weird door wiring issues
  • Dakar09
  • Oct 20, 2026
Dakar09
D
