Can you call up paxton and see if they will switch one out for you? I don't think anybody makes a kit with the 2000 in it. I don't see why they wouldn't switch out the 1200 for the 2000 and just charge you more for the 2000.
I think the head units interchange, so if you order a kit from paxton it shouldn't be an issue to have them swap it out, for a few additional $$'s of course.
All blowers are the same,just have different brackets,plumbing etc. You can use a Procharger,Vortech,Powerdyne, the only thing that changes is the eficiency of the compressor,the CFM,and it RPM limit. Mine is a SN2000,with a limit of 39K RPM and max out at probably 11-13 psi.The Novi 1200 should be a pretty good unit.The Sn was a ball drive and the Novi is a gear drive,thats why they whine.Paxton had a problem with the bearings on the SN's so Craig Connely bought the right to them and re sells them now.
