Setting the timing:
Paint the mark on the harmonic balancer with paint -choose 10 degrees BTC or 14 degrees BTC or something else if you have NO2 or other power adder. I try to paint TDC red, 10 degrees BTC white and 14 degrees BTC blue.
10 degrees BTC is towards the drivers side marks.
Note: setting the timing beyond the 10 degree mark will give you a little more low speed acceleration. BUT you will need to run 93 octane to avoid pinging and engine damage. Pinging is very hard to hear at full throttle, so it could be present and you would not hear it.
Simplified diagram of what it looks like. Not all the marks are shown for ease of viewing.
ATC ' ' ' ' ' ' ' ' ' '!' ' ' ' ' ' ' ' ' ' BTC
---------------- > Direction of Rotation as viewed standing in front of the engine.
The ' is 2 degrees.
The ! is TDC
The ' is 10 degrees BTC
Set the timing 5 marks BTC. Or if you prefer, 5 marks towards the driver's side to get 10 degrees.
To get 14 degrees, set it 7 marks BTC. Or if you prefer, 7 marks towards the driver's side to get 14 degrees.
The paint marks you make are your friends if you do it correctly. They are much easier to see that the marks machined into the harmonic balancer hub.
At this point hook up all the wires, get out the timing light. Connect timing light up to battery & #1 spark plug. Then start the engine.
Remove the SPOUT connector (do a search if you want a picture of the SPOUT connector) It is the 2 pin rectangular plug on the distributor wiring harness. Only the EFI Mustang engines have a SPOUT. If yours is not EFI, check for a SPOUT: if you don’t find one, skip any instructions regarding the SPOUT Warning: there are only two places the SPOUT should be when you time the engine. The first place is in your pocket while you are setting the timing and the second is back in the harness when you finish. The little bugger is too easy to lose and too hard to find a replacement.
Start engine, loosen distributor hold down with a 1/2" universal socket. Shine the timing light on the marks and turn the distributor until the mark lines up with the edge of the timing pointer. Tighten down the distributor hold down bolt, Replace the SPOUT connector and you are done.
The HO firing order is 1-3-7-2-6-5-4-8.
Non HO firing order is 1-5-4-2-6-3-7-8
Setting the timing:
The ' is 2 degrees.
The ! is TDC
Thanks for the detailed info, that is very helpful. Also I looked all over the cap and I couldn't find a "1" on it anywhere. That's why I was lost. Thanks again
Many caps aren't marked with the "1".
BTW, jrichker's pic is viewed from inside the car looking forward. Don't know who ever views the engine from that vantage point, when working on it.
Good point! I overlooked that fact. Does the same apply to cars?
Could be wrong, but I think it's always viewed from outside the vehicle into the engine compartment. Works for front or rear engine, but don't know about mid-engine, which might be from under the vehicle.
Many more orientations for aircraft. The navy does it better: port & starboard, bow & stern; doesn't matter where the pilot seat (or any other seat) is located. Aircraft use P&S and there it ends.
The diagrams I posted read the same if you sit in the driver's seat or stand in from of the car. The distributor doesn't move just because you changed positions. The distributor is in the front of the engine and it is your point of reference. Everything remains the same relationship to it no matter where you sit or stand. Use the diagram and everything is just were it is supposed to be.
