nx kit
bakes5_0
162
adrian,mi
what else will i need to compliment my nx kit for it to be reliable with no glitches....?? oya and the most powerf out of it??
like a purge is that somthin helpfull considering it is a wet kit??
if so which one to go with ??
fuel pressure shutoff valve??
i need to know everything i will need that didnt come with my kit ...??
and i was gonna call bassani but with the mid length headers will i need o2 extenstion or will they be alright???
thanks
baker
i have posted this b4 but i need to know everythin so i can orderin anythin i might need
I have a NX wet kit on my 96 here is my opinion on what you need:
Timing adjuster
NX purge valve/ bottle heater kit (heater makes a big diff so does the purge it gets rid of air in the line and after your done running you can purge all that remains out of the line to take the pressure of off the noids)
A second bottle (runs out quicker than you think)
Run 100 octane if you are going to run a 100 shot or higher.
Go atleast one heat range colder on the plugs. (dont use plats use irdium or regs)
Set gap to .35
Slicks if you want to hook up (beware I snapped my axles with slicks off of the bottle)
hope that helps you out.
