  • SN95 4.6L Mustang Tech
O/R X-Pipe problems
  • Thread starter Thread starter four.six
  • Start date Start date Jun 19, 2005
F
four.six
443
Corpus Christi, TX
Jun 19, 2005
  • Jun 19, 2005
ok mustang crew, i put an x-pipe on my car.. i am getting a bad leak . it is coming from the driver's side where the x-pipe connects to the manifold. the UPR is not a great fit right there. the last time when i had it on my gt, i just used shorter bolts and that fixed the problem. my question is, what size are those stock bolts that connect the x-pipe to the manifold??? the last time i just used 2 bolts i had lying around the my garage that i found... well my gt is no more, and i forgot to get those bolts when i got my x-pipe off. so now i guess i have to go buy em... i guess i could just take the bolt off and WALK to the parts store, but i would rather just have the bolts already... thanks guys.
blackmustang01
Sweden
Jun 19, 2005
  • Jun 19, 2005
I have the same problem, and everyone is referring to Napa studs # 600-1819. I believe the size is 10 mm x 1.5 mm (M10). And, you did use the 1.5 inch piece of tube with a cone as a seal on the driver side, right? Well, I didn't.. thought it was an adapter of some sort.. I mailed UPR and asked and they tolded me what it was for. Now I have to do it all over again...
F
four.six
443
Corpus Christi, TX
Jun 19, 2005
  • Jun 19, 2005
I did see that piece... i was supposed to put that on my car?? oh *****. i think i might of thrown it away. i too thought it was an adapter. where does that piece go???
blackmustang01
Sweden
Jun 19, 2005
  • Jun 19, 2005
It goes between the X-pipe and the manifold/headers on the drivers side.
F
four.six
443
Corpus Christi, TX
Jun 19, 2005
  • Jun 19, 2005
when i put that piece on, will i still need the shorter bolts or will that take care of my problem??? thanks dude.
blackmustang01
Sweden
Jun 19, 2005
  • Jun 19, 2005
Hopefully not. When I told the Ford Technician who helped me with my car about this piece that we left out, he said OK, so they thought about the problem with the studs...that would fix the problem!
F
four.six
443
Corpus Christi, TX
Jun 19, 2005
  • Jun 19, 2005
cool, thanks. im gonna go try and find that piece and put it on right now.
M
Mustangl3
242
willow grove, pa
Jun 19, 2005
  • Jun 19, 2005
I didnt put htat piece on with my mac h pipe and when i found out wat it was for i started the car and checked teh connection and it didnt seem like there was a leak but maybe thats because the car ws just idling?
M
Help! 2003 GT misfire when hot
  • Modular03
  • Feb 10, 2026
SN95 4.6L Mustang Tech Feb 13, 2026
Mustang5L5
J
Exhaust manifold to Y-pipe nut & stud dimensions?
  • joeybuddy96
  • Jul 7, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jul 9, 2026
joeybuddy96
J
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
Fox BBK X-pipe replacement Cat?
  • TIGGER
  • Aug 26, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 26, 2025
AeroCoupe
  • Gulftown980x
  • Jul 29, 2026
squeak93
