O2 Bung Placement
  • Thread starter Thread starter JD1964
  • Start date Start date Mar 21, 2014
JD1964
there is enough sticking out to grab on to
3,647
1,670
194
Maryland
Mar 21, 2014
  • Mar 21, 2014
Disregard concerns with cats when answering this question.
I'm choosing where to weld in the o2 bung for a wideband. I have shorty headers and xpipe. The x joint in the exhaust pipe is just behind the bell housing and right under the gearbox. I was thinking of putting the bung aft of the xpipe connection. This way the single sensor could be sampling a mix of both banks.
The instructions in the wideband kit say to place the bung at least 24" back from the engine. Since my xpipe connection is closer to the front anyway, do you think theres a problem with mounting the bung just to the rear of the x connection? The bung would be just prior to the trans cross member, which is at least 24" behind the engine.
madspeed
Colonel Mustard
1,332
204
a van down by the river
Mar 21, 2014
  • Mar 21, 2014
Sounds like a fine spot
Reactions: JD1964
toyman
1,944
54
79
Vernon BC
Mar 21, 2014
  • Mar 21, 2014
The bung needs to be in the 10 - 2 o'clock position to ensure moisture (condensation) doesn't pool around the sensor element. The 24" from the engine can be read as 24" from the collector flange. The intake flow due to design causes the drivers side to run leaner than the passenger side. Because of this most will locate the WB O2 sensor on the driver's side on the mid-pipe.
84Ttop
5 Year Member
Jul 2, 2009
5,222
3,255
204
South Jersey
Mar 22, 2014
  • Mar 22, 2014
∆∆∆ This exactly!
JD1964
3,647
1,670
194
Maryland
Mar 22, 2014
  • Mar 22, 2014
84Ttop said:
∆∆∆ This exactly!
Check!
PLX inst also say to angle the bung 15 degrees in the direction of the exhaust flow which I plan to do.
Grabbin' Asphalt
2,029
310
124
Atlanta, Ga
Mar 22, 2014
  • Mar 22, 2014
John Dirks Jr said:
Check!
So is that speaking of the element in the bung leaning back toward engine or leaning toward rear of car?
JD1964
3,647
1,670
194
Maryland
Mar 22, 2014
  • Mar 22, 2014
Grabbin' Asphalt said:
So it that speaking of the element in the bung leaning back toward engine or leaning toward rear of car?
Sensor tip which protrudes into pipe should face away from the engine at 15 degrees angle.
Not sure why but maybe to help keep carbon from fouling the sensor.
Reactions: Grabbin' Asphalt
madspeed
Colonel Mustard
1,332
204
Mar 22, 2014
  • Mar 22, 2014
Correct, away from engine
Electrical Innovate PSB-1 is DOA? Am I an idiot? All plausable. Please Help
  • Dontknowchit
  • Apr 26, 2025
Fox 5.0 Mustang Tech Apr 26, 2025
Dontknowchit
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
  • 1994 - 1995 Specific Tech
7K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
Fuel Running lean but no o2 sensor codes?
  • Creomod
  • May 22, 2021
5K
Fox 5.0 Mustang Tech Sep 4, 2021
manicmechanic007
On3 Performance Install Tips
  • flstang65
  • Dec 15, 2019
12K
1996 - 2004 SN95 Mustang -General/Talk- Mar 17, 2023
atomicfox236
A
For Sale 1994 GT 5L Trickflow h/c/i Tremec TR3550 Saleen copy - $7000 (Ann Arbor, MI)
  • no_fox_given
  • Mar 21, 2019
9K
SN95 Mustangs For Sale (1994-04) Mar 21, 2019
no_fox_given
