Well, this build is getting aggravating! Newest problem... Been running down a bad ground problem all week. Found out that Pin 46 in my ECU is fried, which gives me no voltage for a variety of sensors (tps, bap and self test). In the process of chasing this, I fried a second ECU as well. I'm going to take them to a local computer repair shop tomorrow and see if they can repair the circuit.
The culprit?! Previous owner was using an O2 sensor harness for an auto and I am running a 5 sp (A9L). It took a lot of research and searching, but finally found the son of a gun.
So my question is...How do I modify my auto harness to work with my 5sp computer? I have read numerous posts that say it is easy, but no one actually tells how to.
I hope this saves someone a lot of heart ache and time. It all started after I couldn't set my TPS, which uses pin 46 as its ground.
Hopefully someone can answer my question.
Thanks!
Thanks!
