  • SN95 4.6L Mustang Tech
O2 sensor bank 2 sensor 2
  • Thread starter Thread starter JamGtStang
  • Start date Start date Sep 13, 2004
J
JamGtStang
162
Santiago de Cuba, Cuba
Sep 13, 2004
  • Sep 13, 2004
I need help on this one guys, I just got a check engine light and is throwing P0158 and P0156 codes which both are realted to the o2 sensor do you guys know which is bank 2 and sensor 2? also whats the differece between upstream sensor or downstream sensor
Thanks in advance
JM
Ps. My car is running really bad, when you hit the throttle, its like it waits for like a second and then starts to go. Is this in any way related to the o2 sensor?
MT1083
1,033
Charlotte, NC
Sep 13, 2004
  • Sep 13, 2004
The upstream sensor is before the cat and the downstream is after the cat. I believe the only purpose of the downstream sensor is to measure catalyst efficiency. Your code is for drivers side downstream sensor.
DELOS02GT
461
Naperville, IL
Sep 13, 2004
  • Sep 13, 2004
I had the same issue after I put on the Prochamber and installed the Diablo tune. I thought it was a bad O2 but the car was running VERY lean. Did you make any changes to the car before the light came on?
COramprat
...I can take it. I think.
20+ Year Stangneter
Mar 2, 2003
8,474
1,463
223
Sea of Tranquility
Sep 13, 2004
  • Sep 13, 2004
The O2 is probably bad. If you had aftermarket midpipe it would give you a catalyst below acceptable range code. I had the same code on my Expedition. Replaced the O2 and that cleared it up.
J
JamGtStang
162
Sep 13, 2004
  • Sep 13, 2004
Do you guys know if thats going to make my car run like shiet
J
JamGtStang
162
Sep 13, 2004
  • Sep 13, 2004
BTW thanks for the prompt reply
COramprat
20+ Year Stangneter
Mar 2, 2003
8,474
1,463
223
Sea of Tranquility
Sep 13, 2004
  • Sep 13, 2004
It could. Anytime the CEL is on it could be affecting the way the computer handles it's management of the engine.
  • Gulftown980x
  • Jul 29, 2026
squeak93
A
P0036 P0056 P0137 P0157 2020 Ford Mustang GT
  • AmkoA
  • Jun 16, 2026
  • 2024+ (S650) Mustang -General/Talk
2024+ (S650) Mustang -General/Talk Jun 16, 2026
AmkoA
A
G
2006 Mustang GT o2 Sensor Wiring Issue Car Bogging/Choking
  • GCantero93
  • Sep 5, 2025
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 6, 2025
A
2020 Ford Mustang GT P0036, P0138, P0141 02 sensor help
  • AmkoA
  • Jul 29, 2025
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Aug 5, 2025
skkrtis
L
2004 Mustang Oxygen (O2) Sensor Issue
  • letumeternum
  • Dec 30, 2024
Lexiii12
L
